Originally posted by FirebirdGT
View Post
My turbo build
Getting closer, I think I can drive it down to the shop to get my tires and down pipe to exhaust routed, no WOT runs yet. Maybe Thursday we got rain today and supposed to be rain tomorrow. Going to call and get a appointment for beginning of April. Their usually a week or 2 backed up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Originally posted by 2.8 Bird View PostTake a video. Love to hear how it sounds now.Last edited by ssms5411; 03-29-2022, 10:42 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got my appointment for April 7th, 8am. Hopefully it makes it there and back up the mountain. Scratch that, no one to watch the puppy, making it for the following week. Have it for the 14th.Last edited by ssms5411; 03-30-2022, 11:37 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Should of mentioned this earlier, but those who install the EBay turbo headers will have to move the power steering res. and on the passenger side header you might need to hammer the heater box back alittle to get the O2 sensor to fit, mine was way off so it was hammered in quite a bit. Don’t know about the EGR since mine is deleted. That’s about all the problems we ran into besides the my GT35R being too tall for the hood, so double check the clearance of your turbo.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got some more tuning in today, part throttle is great, probably couple more runs and should be tuned. Still smoking pretty bad from the coated pipes, those who get the kit, don’t coat the pipes just use heat wrap. I did both but the 2000 degrees heat paint is burning off like crazy and it’s cool out and I really haven’t gotten on it hard.Last edited by ssms5411; 04-03-2022, 09:59 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ran into a problem yesterday, went to start the Camaro and just got a click No start, replaced the battery, Damm voltmeter was messed up showing 8-9 volts even on my truck, so bad voltmeter cost me a battery, still just a single click so ordered a starter. Should get it Monday. In the meantime I’m going to wack the starter to see if it will turn over. If it’s not the starter then having it towed to the shop. Looked at fuses, tried different key, reloaded the tune, checked wires.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Tapped the starter today, no luck, double checked the starter connectors, will try jumping the wires to see if it clicks to start and check my ground wires tomorrow.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the starter early today, put it on and still nothing, called a mobile mechanic I know, waiting for him to call back. Disabled Vats and still nothing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So found that the crank fuse isn’t getting power, so might be my aftermarket alarm isn’t letting me get 12 volts to the ignition. Anyone no what color the ignition wire is ? Found the aftermarket alarm module, can’t really get to it to try and find where they splice d the ignition wire , will try again tomorrow.Last edited by ssms5411; 04-09-2022, 07:06 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I think I found the problem, bench tested the starter and it’s fine, and it’s getting 12.5 volts but I’m not getting a ground on it so I have a bad ground wire somewhere, checked the main one off the battery, it looks good so need to find the other ones. Anyone know where the other ground wires are?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Also to let you guys know eBay intercoolers have a 3-4 psi drop, so only seeing 6 lbs of boost. Either I’ll put my 14ib spring in or use the boost controller, to get 10lbs of boost. Still pretty quick at 6lbs though. The big intercooler is keeping my IATs low like 70-80 degrees so far. Pretty good.Last edited by ssms5411; 04-11-2022, 10:11 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Who's your mobile mechanic?Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
