My turbo build - FirebirdV6.com/CamaroV6.com Message Board
My turbo build
    replied
    Didn’t get to tuning, snow and rain I hope this winter storms would go away. Have a small oil leak at the oil pressure sensor where I tapped for the oil feed for the turbo. At higher rpm’s , cold my oil psi is 90, hot 20 psi. And cruising 40-60 psi. Waiting on thread sealant and some fittings, going to go ahead and mock up my oil cooler and fan, see if I need to order longer steel braided hoses.
    Leave a comment:
    replied
    Didn’t get to it, worked on my moms car and other stuff and rain yesterday then snow today. Ill get it done eventually.lol Should only take a couple of runs to dial in the A/F then might add some timing back. Only at 11-12 degrees.
    Leave a comment:
    replied
    Looks like the thread locker worked at idle but we’ll see after some good WOT runs, hopefully this weekend. Almost a week now and coolant is fine and no puddles under the crank pulley so might be good.
    Leave a comment:
    replied
    Found my Vbands were loose again so trying some red thread locker on them, see how that works out. I think what I saw was condensation from the turbo pipes, that’s why I never found the dye on the ground or anywhere else.
    Leave a comment:
    replied
    Originally posted by 2.8 Bird View Post
    I never liked how GM designed the reservoir. It's just not efficient.
    Anyway, I tried sending you a PM concerning the pump,but it keep saying I wasn't authorized.
    Yeah, pretty much a pain, I’ll try and PM you my email.
    Leave a comment:
  • 2.8 Bird
    replied
    Leave a comment:
    replied
    Got the reservoir line changed and can’t find anymore signs of coolant leaking. I guess will see. Finally going to start tuning again.
    Leave a comment:
    replied
    As far as the reservoir routing my mechanic said to put the radiator line at the bottom and let it vent at the top. Going to do it tomorrow. That’s pretty much what I found online too.
    Leave a comment:
    replied
    Took off the TB to plug the intake side pcv on the upper intake, only had it plugged on the TB side. Went smoothly but after putting it back together and reving it , I noticed some coolant spraying out one of the coolant hoses off the turbo. Doesn’t leak when at idle just when reving, so going to replace both turbo coolant lines. Might have to take the turbo off , not sure.Went back out to see if it would leak again but it didn’t leak, double checked the coolant hoses and found nothing. I don’t know now.
    Leave a comment:
    replied
    Also anyone have an idea how aftermarket resivoirs hook up to our 3800’s? It has a spot at the bottom and 2 spots at the top. I plugged the bottom and ran the hose to one of the top ones and plugged the other top one. Any suggestions would help me alot. I think I need the hose to go to the bottom of the res. and block the top ports but I’ll wait and see what people say.
    Leave a comment:
    replied
    I think I found the problem, my resivoir was the culprit, I didn’t have a plug on the one side so when it heated up and cooled down it leaked out coolant. Put a plug on it few days ago and it’s just condensation now from the turbo pipes where I was seeing coolant and I’m not losing any coolant anymore. I’ll give it a few more starts and if it’s good I’ll take it for a spin.
    Leave a comment:
    replied
    Checked the trans mount today, got a couple of half turns, didn’t really feel loose, it’s a poly trans mount so shouldn’t be broken or anything like that. Exhaust looks fine, clears everything fine. Got the car cover on it last night with the cable holding it on through the bottom. Good thing to since it was windy and snowing last night. Probably look at the leak tomorrow or the next day.
    Leave a comment:
    replied
    Didn’t feel up to checking on it today, lifted instead. Did start it up and let it warm up to temp. No noise or vibration since setting the idle at 900 rpm’s. But did notice a little vibration when reving. Don’t know if the balance shaft deleted would cause that, still will check the trans mount.
    Leave a comment:
    replied
    Originally posted by zlexiss View Post
    When I was tracing a Mini oil leak I found the 365nm lights worked a little better than the usual 395, this set did me good: https://www.amazon.com/dp/B08M9LY168
    Thanks I’ll check it out.
    Leave a comment:
  • zlexiss
    replied
    Leave a comment:
  • mdiesel
    which balancer do i need
    by mdiesel
    so my engine was originally an L36. upon disassembly i found the crank and rods were out of spec and needed to be replaced. I have a new crank, and i...
    2 days ago
  • mdiesel
    torque converter
    by mdiesel
    not sure what some of you guys with 3.8l's and 4l60e trannys are doing for converters. None of the typical converters that fit this tranny and v8 models...
    6 days ago
    2001 supercharged 3.8 Camaro
    Guy in the FBody car club is selling his 2001 3.8 Super Charged Camaro for $3200, L32 out of a 2005 , with 5th gen super charger, it’s a manual or...
    Hptuners new interface
    Just got a email from Hptuners, you can trade in your cable or Mvpi2 for their new Mvpi3 and you can get 6 credits. I’m thinking about it since I have...
    I think I narrowed down my cold start problem
    I think it’s the fuel pump, after I start the engine on the second try or give it gas it will start fine. Fuel pressure is 44+ psi when It cranks but...
