Nice! It's nice to see a high res picture of that Hotchkis STB on the V6. Looks nice and solid. And good job finding a better breather for the clearance you needed.
Thanks, hopefully get my down pipe routed to the exhaust and my new tires installed by the end of the month. Just working on tuning it. Then move the battery to the rear, install air filter in the fender well and coolant res. So still plenty to do.
ZZP sells a nice breather, I had one but ended up selling it because the strut brace was in the way.
Yeah Edgar I have ZZPs breather, wouldn’t fit, the LS1 breather is cool because you can ditch the filter and run a 3/8th line out of it and then remount the filter and just use a straight barb fitting and mount it anywhere.l
CAR: 1996 3.8 CAMARO M5 converted to A4 Painted from Artic white to GM BlackMODS:
Royal purple fluids, ENGINE: ST 2 cam , 212/212 113 LS, 9:5.1 Diamond forged pistons W/ Total seal piston rings, L32 connecting rods, Comp .105 pushrods, Comp 130lb springs W/Manely retainers, Clev.77 bearings, Comp OER hyd. lifters,, 3" piping,!CAT, 65lb Motron injectors, HPtuners with 97 pcm, Torsen diff. G.M. Motives 3.73's, Prothane poly trans mount, Alm. drive shaft, Transgo shift kit, Corvette Servo, TCI 3500 stall, 45,000 BTU tranny cooler, T/A cover with stud kit. 1" radiator, polished radiator cover.B&M Deep Racing transmission pan(adds extra 2 qts of tranny fluid), ZZP coils ,10.3mm plug wires,5 angle valve job for some Manely Servere Duty II series 1.90/ 1.57 Valves installed with stock .3136 stem size, also bronze guides , guides cut for .600 lift and some more porting/ polishing of the heads, they have been milled .010 already. 1.7 Pro Mags roller rockers. Walbro 255 high flow fuel pump
.SUSPENSION: FE2 SS Camaro 2002 Rack & Pinon 14:4.1 steering ratio , BMR ADJ. LCA'S Chromoly 10.9 bolts, relocation brackets, BMR adj. panhard rod Chromoly, BMR tubular sub frame connectors, UMI tunnel mount torque arm, QA-1 rear ADJ. shocks with 1LE springs, QA-1 front shocks with 300lb springs, rear drum to disc conversion, Powerslot slotted rotors on front and R1 Concept rear D/S rotors on the rear with ceramic pads,UMI 35mm front sway bar, 1 LE 21 mm rear sway bar, PA Racing Tubular K member, PA front Tubular lower control A arms, Spohn tublar upper A arms. 98’ + spindles and brake upgrade , Hawks ceramic pads front and rear.
EXTERIOR: RK sport ground effects, Chrome ZR1 rims 17x9.5" with 275/40/17 Kuhmo tires, SS spoiler, JDM Black rear lights, JDM Black side markers, front black turn singals,Billet grill,removed front bumper support, fog lights, Windsheild Resisvor, Evap, EGR, Plastic under panels, Plastic wheel liners. Converted to 02' wiper arms. 6k 55 watt HID's for the low beams, 10k 55 watt HID's for the highbeams.. Ground effects, RK Sport extended air dam for more flow,. Calipiers painted silver with Dupli color kit, chrome lic. Holder
INTERIOR: GTS Touring seats wide version W/ Spearco seat brackets, Alpine Type R 6 1/2" mids in front, Kicker 3 way 6x9's in sail panel, 2 Kicker titaniums in front doors, Hifonics Brutis amp for mids and highs, Hifonics Brutis 1700 amp for subwoofers, (2)Subthump stealth enclosure, (2)10" Alpine Type X sub, Kenwood double din head unit, 200 sq. ft dead mat. Rear seat delete, new carpet installed, white face gauges, 2 Aeroforce scan gauges in pillar , PLX M300 wideband in center console, SLP FAN CONTROLLER, shift glow vac/boost gauge and fuel pressure gauge in center console removed rear seats, spare tire and jack, Driver & Pass air bags removed, Sparco steering wheel added with MOMO adapter, 02' Camaro leather door panels , polished door sills. Just added Hotchkis stb.GT35R T4 turbo, .63 ar, Tial 38mm wastegate, Tial 50mm BOV, 31x12x4 intercooler, ebay turbo headers and Y pipe, 3" downpipe, turbo smart boost controller.
Also many other mods throughout the years, first mods when I got the Camaro in December 1995 with 18 miles was RK sport ground effects, RKs Dynomax muffler with dual tips and Eibachs 1.5” lowering springs. Then put my stereo in, PPI amps , 2 Kicker solo baric 12’s, and I think it was JL mids and highs. Didn’t start really moddings until 2002 , got RK sports Powerdyne supercharger, started suspension mods, then built the motor. Sold the Powerdyne after 4-5 years, then went with 150 wet shot of nitrous, did that for a couple of years. Camaro sat for about 4 years until I started modding again in 2015.
You left no bolts unturned. You have the most modified v6 fbody ever.
Lots of work, don’t know about most modified.lol
Lol Robert, you need to get busy on your Firebird.
Took the Camaro out for a couple of runs, getting closer, getting part throttle dialed in before I go WOT tunIng. Looked at the boost gauge this time 6lbs at 3000 rpms. Will try and take it out tomorrow if I get the chance, knee was killing me.
