aussie intake
ran into a bump in the build. Its been 6 weeks since I ordered my cam, finally heard from milzymotorsports and apparently they forgot about my order...they never forgot about taking my money though. anyway I told em if they don't have it to me in two more weeks to refund my money and ill get a cam elsewhere... haven't gotten a reply yet, so we'll see
Looks good! you might want to clean up those cut edges so that you don't get rust or a nasty cut if you slide your hand back there when doing work...maybe even line it with a rubber strip like a weather stripping of some sort
Leave a comment:
So I wound up cutting the underside of the cowl to get some extra clearance for the manifold. It did fit before, but just barely. There was probably 1/16" between the underside of the cowl and the top of the plenum, and that was without the gaskets. Cutting the cowl gives almost an inch between the top of the manifold and the windshield wiper arm located above. I also removed the heads, the tops of the pistons are a bit dirty, but normal. The cylinder walls look good, no ridge at the top at all.
Leave a comment:
Originally posted by LETZRIDE View PostNot bad. Seems like a pretty decent size so will be interesting to see how she puts out!
When does that go in?
Leave a comment:
Leave a comment:
Sounds good, I could see around 240 wrhp with a big cam and heads and intakes. Good luck.
Leave a comment:
Just a little update on the project, ordered my cam today. Decided to go with a custom grind from milzy motorsports. 220/230 @.05 duration, .526/.530 lift with 1.6 rockers, 110 lsa on a 106 center line... according to mike at milzy, and Jonathon at comp cams, this cam with my ported heads, manifold and headers should give me about 100 horse over stock and about 40-50% more torque ... we'll see, I sure as **** hope so...
Leave a comment:
Did a little more porting and polishing. Did the intake elbow and also the tb. For comparison I took a pic of the tb stock, big difference in restriction now. I made sure to mark where the throttle plate made contact as to not remove any material at that point, that would make the car not idle right and probly throw some weird throttle actuator codes . I also didnt remove anything after the plate, didnt think it was necessary there. More to come...
Leave a comment:
Originally posted by ssms5411 View PostGT2 is a good cam should put out some good numbers.
Leave a comment:
Leave a comment:
