You said you run straight boots with heat sleeves and it works fine with your headers so Could I actually just keep all my stock spark plugs and wires on and just buy heat sleeves and that would work fine with my headers? so I can get my car out of shop? And I can eventually change plugs and wires
Full Exhaust
Yeah you could do that, just because of the time frame your in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
It ran before with the stockers , I don't see why it wouldn't heres some boot protectors I was talking about:
https://www.ebay.com/itm/2500-Spark-...sid=m570.l131308' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
ssms5411 do you think there's any difference between your 96 and my 02 that would make me need a 90 degree spark plug boot? I hope just the heat sleeves work. I see that in the pacesetter header sticky it says somthing about the 90 degree boot. Think I'm just going to see if the auto part stores have heat sleeves.Last edited by Camaro3800v6; 07-25-2018, 05:49 PM.
Yes mine work great, its a pain trying to get 90 degree wires into heat sleeves, straight should work fine, mine are 10.3 thick wires too. I didn't like the 90 degree boots too close to the header.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If you need I can take a pic of how they are on mine. Let me know. Its getting dark here but I can take them in the morning.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Sounds good, ill snap a few in the morning.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Heres some pics, kinda cramped. You can see the black heat sleeves discolored on some thats where it rests on the headers but the wires are fine.Last edited by ssms5411; 07-15-2018, 02:13 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yes thanks.
heat sleeves on. I drove around a while and noticed it doesn't sound or feel right. I'm not sure if this is just a break in period? But I have a feeling somethings wrong.
when I lightly step on gas and keep the rpms low it sounds good. But at higher rpms it sounds like a baseball card in bike spokes? It kind of feels like a loss of power instead of a gain?
And the strange thing is when I pop the hood it looks and sounds like the engines running strong. I don't hear any weird sounds. And it sounds nice at idle, just a little deeper than it sounded before.
Do you know any problems with egr and these headers?Last edited by Camaro3800v6; 07-18-2018, 08:26 PM.
I don't use a egr on mine, but aslong as it doesn't leak you should be fine, you probably noticed the power band moved up since theirs less back pressure.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Is this baseball card in bike spokes sound normal? Is that how your car sounds when accelerating? Other ways I can describe the sound is.. it sounds like my engine is ticking and sounds kind of like a motorcycle or an old car.
wondering if he could of damaged a spark plug or didn't weld the cat on right or somthing? Check engine light is not on.
By the way when I say higher rpms, I mean anything more then foot very lightly on pedal.
If nothing is wrong, Do you think the sound will get better? Maybe headers just have to break in more.
What are the benefits to not having an egr?Last edited by Camaro3800v6; 07-16-2018, 02:36 PM.
Ticking sound could be exhaust leak, if your egr is working I would leave it alone. Your always going to have rasp sound in the higher rpms its because its a v6 and not a v8. But ticking could be a exhaust leak, I would look into that first.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
