Yeah those top bell housing bolts are rediculous...
i had to put one hand on each side of the tranny to get the bolts in, then use a super long swivel extension and alot of headaches.
The Torque Converter bolts are going to be thread-locked in place, you'll need a way to hold the flexplate in place while you're trying to get them off. OOOOrrr an air wrench.
yeah a pair of vice grips on the flexplate worked surprisingly well.
1999 v6 Camaro M5 Automatic to Manual converted Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
