Tom Henry RS Project Finale
Re: Tom Henry RS Project Finale
Originally posted by 2.8 Bird View PostHib, how do you pass Calif. emission test?
With the cam, heads ported, and other mods you have would cause you to fail the sniffer.
Reality is that if all emissions controls are present and working properly, the camshaft is not to radical–overlap is especially critical–and, most importantly, the calibration is right, an engine with modest modifications can pass easily, as mine does every two years. I should add that the car passes both the "standard" CA Smog Check and the "Enhanced Smog Check" required in most of the urban areas of California such as the Los Angeles area.
I can't stress enough the importance of calibration...tuning! It's easy to do cal at WOT. The hard part is the low-rpm and mid-range part throttle stuff...which involves the part of the engine operating envelope which emissions testing examines.
To get the car's calibration such that it drives nice and passes smog took hours and hours of cal work using HPTuners and a wideband O2S. And then, after we changed injector sizing, I had to redo some of it.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...6 hours ago
