I had a 3” SS hood, had to get a 2.5” cowl hood which was almost a grand. It’s a Hardwood, just have to look where the turbo sits and make sure it will clear.
Finally went turbo
What I did to figure out where the turbo hit was look at where the hood struts attach to the hood if it is not indented just after that then you’ll have problems with a bigger turbo. That’s on a 93-97 hood, don’t know about 98-02 hood’s, might have more clearance. Like on the 3” SS hood the cowl only started at the cowl but didn’t go all the way down. The 2.5” Harwood started at the cowl and then went all the way down. If there’s no indent at the stock supports it won’t fit a aftermarket or bigger turbo on the stock 93-97 hoods. Again don’t know about 98-02.Last edited by ssms5411; 03-03-2023, 12:17 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostAnother problem is the turbo itself, and it’s size they say you can use bigger turbos but that’s bull$hit , mine was maybe a half inch bigger on the compressor side and wouldn’t clear the hood, That’s only a GT35r, I emailed them before I bought the kit and they said no problem. Emailed them after the install, no response. Cost me over $1000 to remedy the problem.
On the 93-97 hoods the support is in the way, so no hammering will work, bought a stock hood for $50, cut the hood and added a scoop. Didn’t want to cut my 3” SS hood, sold it for $400, got a hood that would fit and look good, the Harwood 2.5” did that.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Turbodude View Post
I fixed mine with a hammer tbh
Fiberglass hoods not a option bending and didn’t want to mess up a $400 SS hood, bought a stock one for $50 and had to cut a hole to clear the compressor side and hot side. Looked like crap so eventually got the Hardwood 2.5” hood, so much better and can run a bigger turbo in the future, I got no response from the seller of the kit and they still list that you can run a bigger turbo. So I think they are crappy sellers. I should of just had the hot side made for $1500 and saved so money.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostYeah I deleted my EGR in 2002. I ran a -10an line from the turbo to the pan. Right above the low oil sensor. You want at least a -10an line so you don’t have any oil backing up. Then just tee off the oil pressure sensor with a -4an line to the turbo. Yes Bov gets a line and if there is a top and bottom vac line on the wastegate , bottom vac. to manifold top stays open or you hook it to a boost controller for more boost.
I’ve run it off the TB port where the evap ran from, running it off the manifold is good , it will still see vacuum, never heard of vacuum being bad for a wastegate it only lets out a certain amount of exhaust to maintain it’s spring rate. ATP turbo has a threaded vacuum port so you can tap a port on the compressor side, doesn’t have to be on the turbo just in the pipping, I bought one but have never used it, really no point.Last edited by ssms5411; 04-03-2023, 01:37 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Looks great, what rocker arms are you running?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
