Tell me about it! And LT1 MAF in a “blow through” position close to the throttle body, you can kind of see in the picture
EBay turbo kit
Cool, once mine gets going I'll figure out about what maf to use. I know the Cartunning kit uses a ls1 maf and they get 15 psi so I'll see what everyone else does and go from there.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Turbovert01 View PostZZP uses and recommended the LT1 on there turbo cars, they also offer a mail order tuning option for it and the other basics like injectors and turbo tables to start the car, that’s why I chose it08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Turbovert01 View PostI am running Siemens Deka 60# injectors and AEM 320 lph pump both from ZZP, I put my full mod list on my bio if you wanna check it out. Everything I did was reccomended by ZZP.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Hey speaking of fueling, I just installed that pump and injectors and have 51 PSI at the fuel rail with the engine off. These Fbody's have a fuel return system I believe, and I was talking to Tim about this and he said it should be whatever stock is. Do any of you guys know if I am fine or what stock is?
That sounds about right, when I first did the Walbro 255 high flow I was seeing high fuel pressure, stock is like 44 psi and up, I think I saw 50 psi when I first installed the new pump. Now 17 years later Im right around 44-46 psi at idle and about 48-50 at WOT.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 2 likes
35 sold of the headers, and 7 sold of the full kit. Not bad.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Originally posted by 2.8 Bird View PostHopefully we'll see them here.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Just about finished my cold air intake, still waiting on my drycharger cover for the filter and have to clean up the fog light hole, but for now its functional. For those wondering it IS possible to get 4 inch pipe past the strut tower and battery, but it requires some fab work. The radiator overflow tank neck has to be shortened and pointed the other way, and the very front of the strut tower has to be cut with a ~5 inch semi circle (I used half an exhaust pipe pictured in last photo) welded in to make it work. I also deleted the fog light because I wanted to create a sort of ram air effect. I'm overall happy with how it came out, and I'm glad I was able to retain the battery in its stock location. :D
- 1 like
Looks good, yeah pretty crazy fitting 4" pipe by the battery, good job.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Anyone got theirs up and running yet?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...4 weeks ago
