Billet 6061 1/2" transmission spacers. - FirebirdV6.com/CamaroV6.com Message Board
  • #61
    Re: Billet 6061 1/2" transmission spacers.
    I came upon this thread, what years does this fit? It is for the ES Tranny mount. For others just coming upon this thread. Who would this help
    • #62
      I'm in.
      Old Car = 12.679 @ 106.5 on 150 dry shot.
      New Car = 2010 3.6l 304hp Camaro
      • #63
        Was made to match the mounting hole in the 5 speed tranny. Will work for any mount on that transmission that needs a spacer. If somebody gets to me to tell me if the A4 has the same spaced holes or what I can do something with that too.
        • #64
          If the weather clears up here I'll be changing out my t. mount so I'll check the measurements for you. What length/thread size etc. bolts does this require? My dad is a tool and die maker so he could probably make the spacer for me for free. Anyways, like I said, if I can get to it before I head back to school (sunday, im on spring break now), i'll get the dimensions to you.
          EDIT: When I look up the transmission mount, I'm not finding a different one for the automatic or manual, so I'd assume that the gap would be identicle?
          2000 v6 a4 Camaro
          • #65
            Thanks Taheen for that diagram. It came in super handy and made installing my Prothane transmission mount a breeze! Thanks again!
            <a href=\"http://home.comcast.net/~smpuskas/\" target=\"_blank\">http://home.comcast.net/~smpuskas/</a><br /><br />3A C-Fiber Pedals<br />Free Ram Air Mod + K&N<br />RK Sport Air Temp. Module<br />Flowmaster American Thunder 2.5\' Cat-Back<br />Chrome/Red Shifter<br />White Rally Stripes<br /><br />Audiobahn 12\' AE1200 Sub<br />Bazooka EL 1500 Class D Amp
            • #66
              Re: Billet 6061 1/2&quot; transmission spacers.
              what size bolts did you use? i just made my own spacer with the picture you included (nice work btw) i just need to figure out what size bolts to use now :excited:
              • #67
                I think I posted the bolts before when I did mine with rubber bushings about 3 years ago, still holding up fine, with the M5 I had in it and the A4 I put in it.
                • #68
                  took the design you posted..worked perfectly..thanks!!!!!
                  :bowdown:
                  • #69
                    Awesome! Glad to hear it is being put to use. :)
