Post your cam/heads setup for the sticky... - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Post your cam/heads setup for the sticky...
    Joe
    210/220 .512/.512 @ 112
    Abbott Racing Heads Stage 3 heads
    130# springs
    RWHP-not dynoed yet
    • #17
      Eric
      Comp GT2 216/216 .507/.507 111LSA
      Stock heads
      LS6 90# springs
      Comp pushrods
      Comp OE hydraulic lifters
      No dyno/track times yet
      • #18
        Eric
        Custom Comp Cam 224* 224* .509 .501 @ 112 LSA + 4 degree
        Stock Heads Fully Ported/ Polished 5 angle valve job, w/ portflow series valves. Mixer vanes shark finned
        Comp Springs, retainers, hardened pushrods, hydraulic lifters
        Comp 1.6 roller tip rockers
        • #19
          Comp Cams GT2 216/216 .507/.507 111LSA
          Stock Heads P&P
          Stock Lifters
          Stock Springs
          Stock Pushrods (All replaced OEM new)
          1996 Chev Camaro RS 3.8<br /><a href=\"http://www.cardomain.com/ride/2233257/1\" target=\"_blank\">http://www.cardomain.com/ride/2233257/1</a>
          • #20
            up date
            same cam with 1.7 rockers
            OE lifters
            www.turbov6camaro.com
            1997 3800 Series II Camaro
            • #21
              Chad
              Abbotts Racing Heads NA cam
              210/220 .512/.512 112 LSA
              Stock Heads
              LS6 Springs
              • #22
                Taylor
                Comp Blower Cam
                210/220 .512/.512 115 LSA
                Stock heads
                Comp 7.00 pushrods, Comp 105# Springs, Comp steel retainers.
                Camaro V6 - 14.3 @ 96mph
                Camaro SS - cam/boltons/m6/tune
                http://www.crfhq.com
                • #23
                  Abbott Racing Heads N/A Cam
                  Abbott Racing Heads Stage III P&P Heads
                  130lb Comp Cams Valve Springs
                  Hopefully 250rwhp?
                  • #24
                    Shane/Nachius
                    Comp Cams custom grind
                    210/220 .320/.320 (.512/.512 at 1.6 rocker) 115LSA (this is at a 115IC) .040" smaller diameter base circle.
                    THR Custom big valve heads w/ flow numbers
                    Intake Exhaust
                    67 54
                    134 112
                    185 154
                    214 183
                    231 196
                    238 202
                    241 206
                    Comp 105# springs.
                    4.2L forged stroker w/ 8.2:1 compression in a GTP currently being built. Will have numbers by the end of next month.
                    • #25
                      Jason
                      CompCam 16.233.4 212/212 .440/.440 LSA - 110
                      P&P Stock heads with matched intake
                      Comp lifters/springs
                      approx hp: 200
                      I think the only built 3.4 using stock heads.
                      http://www.cardomain.com/memberpage/799659
                      • #26
                        Erik
                        210/220 .512/.512 on a 112LSA
                        Stage 2 zzp heads
                        90lb springs,
                        OE-R comp lifters,
                        Double rolling chain,
                        Comp pushrods.
                        <a href=\"http://www.cardomain.com/id/lucky19\" target=\"_blank\">http://www.cardomain.com/id/lucky19</a>
                        • #27
                          Vinnie
                          zzp gt3 comp cam
                          p&p intake and heads
                          • #28
                            Jarl K.
                            Comp 212/212 duration 470/470 lift@valve 110 LSA
                            Stock heads...
                            Comp #980 springs
                            Crane Gold race rockers 1.6
                            • #29
                              where did you get the 3800 fender decals?BTW my camaro is pretty stock
                              :cold air intake(K&N Filter)
                              :Flowmaster 80series muffler.
                              :custom SS styled exhaust.
                              :160* thermostat.
                              • #30
                                :160* thermostat.
                                wrong forum, wrong thread
                                http://forum.camarov6.com/forumdisplay.php?f=13
                                ^search here
