So to sum up this thread, I found my cousin husband to be is a mechanic , and he did the head gaskets for $600 amazing deal, and I drove it back and it had no power to it same as when I drove it down to him , would just chug along, looked at it and my timing was stuck at 10 degrees with a 1350 DTC code. Looked up the code and says faulty ICM harness , so get a new harness , half way through wiring it in I noticed a white wire that was cut on the harness and tuck under the other wires , so I finish wiring up ICM harness used the wire that was tucked down instead of the white wire that came from nowhere. Started it up and I get my timing back. So one of these places I took it to wired a different wire in and tucked down the one that supposed to be used, So they would of made $1800 of me if I would of let them rewire my car the first time. Bastards, then I found out that 2 of my spark plugs were missing after I just did wires and they were all there. SO never taking it to that shop , yeah all this happened when I was searching for shops, they would keep it a few days and then say too modified or don't have the time., I blew the water pump this last week so still no driving but 2 more weeks and that will be fixed guy that did my headgaskets is coming up to do it. Rates are very resonable.SO once I get it out on the road Ill finally be done. Thanks for all your guys help.
Damm Head gasket........................................
Please IM me with what shop you had issues with - I want to stay clear of them.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
