ok so after using the search button ALOT i have decided to stick with a 75 dry shot and 100-125 tops on the track. now would the #24 bocsh injectors from zzp be ok? I have a dynotune dry kit thats gunna be going on a rebuilt engine. Also upgrading to a walboro pump. any info from the nitrous gurus?? ive read so many different threads saying go with 24# all the way to 36# lol. thanks in advance!
#24 injectors?
Re: #24 injectors?
well at 75 shot, you can stick with stock injectors. 100 would be my max, and I would want to have a wideband to see what the a/f ratio is on the 100 and stock injectors. Or get someone with hptuners and see what kind of injector duty cycles you are hitting at 100 shot.
Re: #24 injectors?
Originally posted by 97rs4life View Postwell at 75 shot, you can stick with stock injectors. 100 would be my max, and I would want to have a wideband to see what the a/f ratio is on the 100 and stock injectors. Or get someone with hptuners and see what kind of injector duty cycles you are hitting at 100 shot.
also the other mods im planning is of course full exhaust/ intake. and a good nitrous cam from zzp ( still undecided on that one) . stock heads, crank and pistons. also have 3:42 gears with posi out of a trans am.Last edited by camarov696; 01-07-2010, 07:20 PM.
Re: #24 injectors?
if your going to buy new injectors, dont waste your time with 24lb, you will want more power eventually and wish you had gone bigger, get some 36lb'ers for now, you can find them for 50$ everywhere
also, i would get a lean cut off for your nitrous so if you go to lean the nitrous stops so you dont f*ck something up
Re: #24 injectors?
Originally posted by Fondle View Postif your going to buy new injectors, dont waste your time with 24lb, you will want more power eventually and wish you had gone bigger, get some 36lb'ers for now, you can find them for 50$ everywhere
Re: #24 injectors?
Originally posted by camarov696 View Postyea im putting in a fpss. 36# wont be overkill if i dont move up in power?? BTW very nice turbo build!:tup:sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: #24 injectors?
I take it your car is a 96 from your sn. If so then the 36# GTP injectors are direct swaps. search grand prix forums as well for a set for sale. clubgp.com or 3800pro.com are good sites to find injectors as well in their for sale sections.
Also for a/f gauge, don't get a narrowband one, get a wideband one if any. Narrowband will tell you nothing but give you a light show.
If getting it tuned on a dyno, they will put a wideband in the tailpipe to get readings
Re: #24 injectors?
Originally posted by 97rs4life View PostI take it your car is a 96 from your sn. If so then the 36# GTP injectors are direct swaps. search grand prix forums as well for a set for sale. clubgp.com or 3800pro.com are good sites to find injectors as well in their for sale sections.
and let me get this straight, if i swap out the injectors and go for the 36#'s, i can get it tuned to run fine NA but still have plenty of injector left if i ever decide to run a bigger shot?
Re: #24 injectors?
correct, it will run fine NA once tuned for the injectors. Without a tune it is gonna be bigtime rich.
Re: #24 injectors?
the motor is the same from 95-98, 99 went to the straight intakes
Re: #24 injectors?
It might just be worth it to add a fuel portion to your N20 Setup. You wouldnt have to worry about upgrading the injectors. I was running a 125 shot with a fully built Heads cam intake motor. The only fuel mod I had was a walbro 255 pump. I was making 370 rwhp on a stock tune and having a A/F ration in the low 10's the entire time. Just a suggestion.Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...14 hours ago
