Can i see come pics of ya'lls installs. THinking about getting the Brand X kit with single shot(wet). Wanted to see underhood pics and bottle mounted in spare tire area if possible.
Install
Re: Install
Wet is really a PITA in these cars. Your only nozzle placement options are in the TB which is too thin to actually get a bite, or to order a TB spacer and mount it there. Not to mention they are more prone to backfires. If you have a mostly stock car, go dry.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: Install
Originally posted by Bird_Of_Prey View PostWet is really a PITA in these cars. Your only nozzle placement options are in the TB which is too thin to actually get a bite, or to order a TB spacer and mount it there. Not to mention they are more prone to backfires. If you have a mostly stock car, go dry.
Re: Install
Originally posted by 97rs4life View PostI ran a wet kit for a couple years. Not really a PITA at all. I just drilled a hole in the tb, inserted my nozzle and used the nut on the inside to hold the nozzle in place. Not hard and as long as the shot size is 100 or less backfires are not an issue
These motors do work really well on dry kits too. For a simple, single shot kit either one will work fine.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Install
Originally posted by Choppers View Postyea i am going wet because i plan on putting an ls1 in it in the future. I am only going to do a 75 shot.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Re: Install
Originally posted by Choppers View Postwhat do you mean maf's, lids, filters?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: Install
i am going to do it right with a fuel coutoff, window switch, purges, nitrous filters....so i think i will be fine. been talking with dave at nitrous outlet. he knows his stuff. i have just been wanting to see some underhood shots and stuff to make it a clean install.
Re: Install
Originally posted by Shodown View PostIf you install it incorrectly or dont have a window switch then have a backfire due to fuel puddling in the intake, the maf, lid, air filter and other parts of the engine will be destroyed and need replaced.
Or have low bottle pressure....<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...9 hours ago
