where can i get a y-pipe? - FirebirdV6.com/CamaroV6.com Message Board
  • where can i get a y-pipe?
    i can only find that one and it includes the cat, which is $400 all together, i just want the y-pipe for now, because im pretty sure that is what is making my rattling noise (thanks to the members here)
    this is for a 98' camaro
    thanks
    Re: where can i get a y-pipe?
    i guess i should make myself more clear, i need the downpipe/ypipe
    basically this:
    without the cat
      I have an extra 2- 2 1/4" openings on one side and a 3" on the other side, bought it and went with a different design. It is brand new from Summit Racing paid $40 shipped. If you want it I would do $25 shipped if you want it. PM me if interested.
        can you take a picture?
        i need the piece that connects to the exhaust manifolds and runs down into the y-pipe and into the cat
        because from what i understand for some reason there is two pipes inside of there, and mine is rattling somewhere
        thanks :D
          like in this picture.. im assuming this is right after the cat where the pipe splits into two pieces: http://forum.camarov6.com/showpost.p...6&postcount=13
            Mine is like this from flowmaster 2-2 1/4" to 3", Summit racing:
              hm
              is the y-pipe welded the the cat? or is it be clamped on?
              i dont think that is going to help me, since i think the rattle is in the downpipe going to the ypipe?
              but really, i have no idea i just want the rattling sound to go away it is so annoying
                The peice that is doubled layered most of the time is the pipe comiing from the drivers side header over to the Y pipe runs under the oil pan, that is where people install a screw or like me just broke out the welder and burnt though the pipes and welded them back together.
                  where exactly should the screws go?
                  just in front of the y pipe in the picture, or should i put them along the pipe that is behind the oil pan?
                    You should be able to feel where it is double up at, then it would be up to you to put the screws in since I have never used screws on it.
                      I have the stock cat and y pipe all still one piece....like the one in the pic. Only 49k miles on it if your interested.
                        does it have the downpipe from the exhaust manifolds?
