i was just wondering how hard it is installin the magnaflow catback exhuast or similar? i wanna know whats in store for me when mine comes in. what should i look out for and does anyone have a write up?
catback install
Re: catback install
Can you follow instructions? Can you screw in bolts? Can you weld if nessasary? Do you have Stands and a jack? If you answered yes to these questions you'll be done in no time!1998 Red T-top V6 Camaro
- K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
Re: catback install
Originally posted by RyanAndyBob View PostCan you follow instructions? Can you screw in bolts? Can you weld if nessasary? Do you have Stands and a jack? If you answered yes to these questions you'll be done in no time!
"Well then this is the kit for you! for only 45 easy payments of $15.95...
But yeah, should go on pretty easily, just make sure you have the car high enough to get the over Axle pipe on there...Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: catback install
But yeah, should go on pretty easily, just make sure you have the car high enough to get the over Axle pipe on there...1998 Red T-top V6 Camaro
Re: catback install
ok cool. i thought the hardest part would be getting the old off. looks like im ganna just hand saw that **** off. i wanna do it all by myself so i can save money and not pay some1 to install it. i will however get it welded later on down the line just to be safe.
how hard is it to get it around the axle?
if anyone has a write up with pics, that would be nice.
Re: catback install
Originally posted by Bonemaro View PostNot too hard. Just get the car jacked up fairly high and you shouldn't have too much grief.
Na, I looked at the magnaflow kit, should be pretty easy.
Just get the car on jackstands as high as you can, and if you wanted to, you could throw a jack right in front of the Pass. Side LCA, and jack up the frame...gives a little bit more clearance when you're trying to get it over the axle...jsut be careful if you start to jack the frame, sh*t can get crooked real quick on those stands...
PS. Bone. I REALLY am diggin the new sig.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: catback install
You can jack the rear of the car on the center of the differential, and I put my jackstands on each side of the differential, just outside the rear swaybar.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: catback install
You want the diff to hang down so the pipes will clear. I removed my LS1 exhaust and installed my Magnaflow in about 2 hours using hand tools. I also removed my stock exhaust in 1 piece.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
