taking off intake manifold? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: taking off intake manifold?
    why not just pull the lower also so u can scrape all the gasket off easier ?
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
    • #17
      cause i dont have another gasket set for that, and i have to drive the car to school tomorrow :(
      + the lower gasket set cost like 50bucks
      • #18
        and is it bad to take my dremel and kinda grind down the ports just enough so that the metal is gray instead of brownish?
        basicly a ruff sand
        • #19
          ok i have the car all back together and everything, question...
          is it normal to have a really ruff idle when you first start it up? it was really ruff, and i got scared so i turned the car back off lol.
          • #20
            how hard is it running? is everything back together right? did you get cr@p on your sensors? air leak?
            WAWA-A-HOLIC
            • #21
              check the air line that goes behind the upper intake
              Originally posted by kala
              I'll have buttsecks with Richard Simmons!
              TEAM BLACK!!!
              parting her out
              • #22
                well i just let the car run and the idle snoothed out, and the car runs fine now.
                i guess gas had to make it back up the fuel lines or something
