will standard paint finishes on headers "burn" off eventualy? I want good looking headers on my Firebird, unlike the crappy rusted out exhaust manifolds...will the paint finishes eventualy rust out or burn off even with wrap on them? or should i just bite the bullet and fork out the extra 100 for ceramic coated headers?
Painted vs Ceramic Coated Headers
Re: Painted vs Ceramic Coated Headers
well the painted will rust faster but if your wraping them does it matter??? coated headers will cut down on engine bay temps and keep the heat in the exhaust gases ( hot gases flow faster). But painted headers are just as good as the coated but if you going for the look of them get coated.
coated headers will keep in heat better? or did you mean wrapped headers? well if im gonna wrap the headers does it matter if it traps moisture or not and corrodes the coating? cause they will be wrapped and it wont be seen.
Originally posted by DHiser27coated headers will keep in heat better? or did you mean wrapped headers? well if im gonna wrap the headers does it matter if it traps moisture or not and corrodes the coating? cause they will be wrapped and it wont be seen.
The coating lasts longer than paint and helps keep engine bay temps down among other things.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
haha ^^^. FYI the paint that comes on the Pacesetter headers is **** IMO. if youre going that route you might as well sand it off when you get em and repaint em with high heat engine paint
does high temp paint do good in the winter? I live in Indiana and I need something that will last through winters and rain. I'm thinkin the way to go is ceramic...so expensive though...
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...1 day ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
