I'm finally get my headers installed. That will finish my exhaust. Pacesetter headers, Carsound cat, and Borla after-cat. I'll try and get some sound clips up for you guys.
Getting headers installed
I'll let you know when I find out how much he'll charge me. But he's also make a 3 inch s pipe for after my cat.1999 Pewter Camaro<br />A4<br /><br />165.3 RWHP 202.5 RWTQ<br /><br />Mods:<br />Borla Cat-Back, Jet Chip Stage 2 PCM, Tranzgenic Cold Air Intake, Pacesetter Headers, Car Sound Hi Flow Cat, Custom S-pipe
What P/N carsound cat are you using? I'm curious because I used P/N 94039 which is a 3" in and 3" out with an o2 bung in it. P0420 is a constant now. Carsound recommends using their 935XX for our setups. Something to consider before welding in a mistake.180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
Unless I'm mistaken, the 935XX cats are designed to pass California emissions. I just installed a 94009 on my Camaro, and it works beautifully. Then again, I'm no longer worried about passing Cali emmisions tests. :D
Edit:
I looked it up, and it's the 930XX that's Cali emissions compliant, *not* the 935XX. My bad.
[ August 13, 2004, 12:49 PM: Message edited by: papismark ]\'99 Silver Camaro M5 T-Tops<br /><a href=\"http://www.cardomain.com/id/papismark\" target=\"_blank\">http://www.cardomain.com/id/papismark</a><br /><br />Intake and exhuast so far. More to come...
I think I have the 94009. But I'm not sure. I'll have to check when I get home. And I would install the headers my self but I can't weld so I'm just gonna have this guy do it for me. He's only charging $150. and he'll only have my car for most of the 23rd of aug.1999 Pewter Camaro<br />A4<br /><br />165.3 RWHP 202.5 RWTQ<br /><br />Mods:<br />Borla Cat-Back, Jet Chip Stage 2 PCM, Tranzgenic Cold Air Intake, Pacesetter Headers, Car Sound Hi Flow Cat, Custom S-pipe
sounds good. im really wanting to know what a borla sounds with a cat and headers? i bet it great [img]graemlins/rock.gif[/img]
Originally posted by NCState98:
Install the headers yourself :cool: The toughest part is removing the manifolds.
my shop wanted a min of $300 for the headers. they've never installed them on a v6 so that was a starting point. Needless to say I took it up to Stefan and Pathogens place and had a great time getting them on. the hardest part is getting the old crap off, but for us it was just time consuming and not necessarily hard.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
