hey just wondering who makes our heads and headers for a 3.8 v6, 98 bird? whats a good brand to go with?
HEADS AND HEADERS
Heads: www.Supersixmotorsports.com or thrasher. SSM is much better service for the heads. I ordered a pair for my car.
Headers: RKSPORT, CIA, and soon to be Pacesetter.
I would get the heads from Pacesetter when they come out. I would buy the heads from SSM they range anywhere from $650 up depending on what you have done to them. Mine were $1000 they are milled, 3 angle valve job, port and polish and new valve springs. Fully assembled.
To compliment the heads get a SSM cam or from Comp cams get a custom grind. And a pair of ported and polished intake manifolds to make some good power. Manifolds also found at SSM.
Stay away from the RKsport headers. I put them on my camaro a couple of weeks back. Man, what a headache. They use two bolt flanges to connect the headers to the Y-pipe, not three bolt. And the flange is really thin. After one weekend of driving around my car was farting outta the connection from the passenger header to the y-pipe.
After some "persuasion" I straightened out the flange and tightened it down over two sandwiched, somewhat thicker than provided, gaskets...it's holding for now, but who knows.1997 Sebring Silver Metallic<br />Camaro RS A4<br /><br />Mods:<br />Aluminum Driveshaft, Z-style hood, headers, B&B Cat Back, fan switch, BMR Suspension, Silver Gauges w/blue interior lights, Clear Corners and Sidemarkers, Power antenna, 18\"x9\" OZ Superleggera Wheels
uhh..no offense..but SMART people get the Y pipe welded to the headers...96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
RK sport flanges warp so no gaskets will work..
Mine are welded..
I was able to swap my heads with out cutting them apart.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
<blockquote>quote:</font><hr>Originally posted by GO3WIDE:
RK Sports are he only headers I have seen, does anyone know of some other brands, especially for the 97 model.<hr></blockquote>
CIA headers. clearimageautomotive.com
Pricey, but quality.
They're made one at a time, to order, so it may take a little bit for them to arrive. Mine were going to ship last Thursday, but are actually shipping tomorrow. Three choices of ceramic coating colors... I got the new Ice Grey.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
Only options available at the moment are RKSport and Clear Image Automotive. Neither one is really worth the money IMO, but if you're going to go with one then here are my thoughts:
- The very design of the RKSport headers is mickey mouse, stay away from them.
- As long as you're going to spend the money on headers, get the quality set from Clear Image Automotive, and throw in the bucks for ceramic coating.-James<br /><br />\'96 3.8L A4 Camaro (SOLD)
I would check out some gm aluminum heads. they're lighter, reduce the detonation threshold of our engines, and are easier to port/polish. check GM's website for them. then have those ported/polished by ssm, port match the intake manifolds to the heads, and get a custom cam. yes, aluminum heads can warp easily if you overheat your engine, but dissipate heat better and are easier to cool. this is how they reduce detonation. you won't get any hp difference between iron or aluminum heads w/ the same configuration. Some people think iron heads make more power because they keep more heat in, but they raise the detonation limit too. this is how everything evens out.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...3 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
