Im havin a huge problem with this dam egr leaking from my pacesetter headers. i have tried everything and still getting that annoying ticking sound. two of my mechanics have worked on it and have tried everything. i asked both of them if we could just block it off but both of them disagreed. What is the worst that can happen by blocking off the egr? i know gas milaege but what else? im lookin at the egr block off plate from zzperformance. will that work? please reply.
EGR Delete
Thanks. I know from zzperformance they sell the plate for 5 bucks, but im not sure if the sim is included with it or i have to buy the sim seperate? if the sim is not included where can i get it?
http://www.zzperformance.com/zzp/pro...koff_plate.htm
i was thinking about just welding the hole shut....... seems better then trying to get the block off plate to seal up....www.turbov6camaro.com
1997 3800 Series II Camaro
the block off plates work pretty well.. that + some ultra-black instant gasket stuff and you will be set on the header side.. the intake side jsut use the block off plate dont want any crap getting in your motor.
[img]smile.gif[/img]
Originally posted by AllTheGoodNamesAreGone:
</font><blockquote>quote:</font><hr />Originally posted by viper04af:
[img]smile.gif[/img] </font>[/QUOTE]for the intake side i was going to try and make that work for my PSI sending unit and the BOV and waste gate... have to figure out how to do that.... guess a tap ad die kit and the right fittings i'll have to look at more when my car is sitting in front of me..
BTW did you notice any knock after removing it?www.turbov6camaro.com
i bought the plate yesterday and im going to put a rubber hose on the EGR and run it up to the front of the car with a valve cover filter kinda like a tiny CAI instead of taking it off cause i dont want the code.
I use the blockoff plate and sim on my car with no problems. My exhaust shop said it was a bad idea to do it as well, but I told them to stfu and just weld the header port closed. Don't listen to mechanics when it comes to things like that. Most of them don't know wtf they're talking about.
I do like all the extra room it gave me in my engine bay: http://home.cfl.rr.com/mkaprocki/Camaro/EGR.jpgMatt
1998 Mystic Teal Camaro M5
How hard is it to hook up the egr sim? also can the block off plate be welded on while the header is still on the car or will it have to be taken off to weld the plate on,which is a pain to get the header off? also im thinkin of havin my headers welded to the y pipe instead of the clamps that are on their now. Has anyone else done this? Im tryin everything i can to get my drivers side header to stop leaking.I already changed the gasket and header bolts so its got to be the egr or the header connection to the y pip. Also i know the egr leak sounds like a ticking sound, but if something else is leaking like the gasket or the connection to the y pipe will it also make the same ticking sound?
Not a good Idea if the car is a daily driver, an egr system reduces cylender temps to get rid of NOX emissions. You ditch that setup and you have the possibility of burning exhaust valves over time. Im not trying to convince you not to but just think of all pros and cons before you start deleting it-Chris<br />2001 Pewter Camaro M5<br />Current Mods: NOS Dry Kit and a few others<br />N/A: 15.5@88.9MPH<br />N2O: ??? <br /> <a href=\"http://www.cardomain.com/id/jtusa69888\" target=\"_blank\">http://www.cardomain.com/id/jtusa69888</a>
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...3 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
