Hey guys, I have an exhaust leak coming from the header side of my egr. The tube is fine, but the piece that bolts to my header is bent and it keeps burning through gaskets. I'm in the process of making some block off plates out of 1/8" steel, and I was wondering if I should put a gasket under the plates or if copper rtv would be good enough. Also what's to keep them from shifting in the future and causing leaks? Would the 1 bolt per plate be enough to hold them? Thanks guys.
egr block off
Re: egr block off
Those of you who deleted your egr, where did you mount your dip stick?1997 Chevrolet Camaro
Re: egr block off
Same place just used a zip tie to the bolt at the head stud.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: egr block off
Yeah that's what I ended up doing. I used a piece of electric fence wire and wrapped it around the tube twice then each end around the stud and threaded the nut back on it. I've got it all done, I just want to wait till the rtv is dry before I start her up.Last edited by espey_16; 06-07-2012, 08:45 PM.1997 Chevrolet Camaro
Re: egr block off
That should hold it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: egr block off
does your dip stick tube ever pull out of the hole when you check your oil? I need to find a way to secure mine in the block, I keep forgetting to hold it in place when I check my oil.1997 Chevrolet Camaro
Re: egr block off
Originally posted by espey_16 View PostThose of you who deleted your egr, where did you mount your dip stick?Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Re: egr block off
I took care of it with some jb weld. Went to check my oil after I wrote my last post on this topic and I could see the bottom of my dipstick as I was looking down toward the starter. The tube was out of the hole it goes in in the block.1997 Chevrolet Camaro
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
