I have seen alot of pictures of cold air intakes on the 3.8 camaro's (Ones from ebay, and failures). Honestly i think mine looks pretty good compared to some ive seen. Mines just spectre brand but i think i did it NICE JOB!!!! CHECK IT OUT BELOW and post yours to compare.
My Intake Design. Whats Yours???
Re: My Intake Design. Whats Yours???
I run a 3.5" flex tubing down into the drivers fender well with a 3.5"to 4" tube and a 4" X 9" K &N filter sits , gets plenty of air, hope to keep it there after the turbo but with 4" tubing all the way with a new filter since that is the coolest spot I have found.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Unique96Camaro View PostI have seen alot of pictures of cold air intakes on the 3.8 camaro's (Ones from ebay, and failures). Honestly i think mine looks pretty good compared to some ive seen. Mines just spectre brand but i think i did it NICE JOB!!!! CHECK IT OUT BELOW and post yours to compare.
I would install that filter down in the fender well to get cooler air instead of still in the engine bay.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
It looks good, but you need to go down farther. Where your filter is now, looks like it wont get much air flow and you're also sucking in hot air from the engine bay. If you keep it there atleast make some kind of block off plate to prevent hot air from being sucked in.
good grief, next time before trying to show off your DIY intake setup, clean that engine bay, lol.
And yea get it down into the fender
your belt needs some attention. and theres a leaf stuck under the body (positive and ground) coupling. lol.
but yes Very good intake. (some advice) "take off ALL the old intake pieces. even the one that's wedged up behind your driver side low beam. I took mine out and you wouldnt believe how much air get to there now.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
