I just purchased a used lid and I am about to install it, is there anything special that needs to be done after its in? Will it run propererly with the increases airflow? My car is stock besides this lid and K n N replacement filter.
Whisper lid install
Re: Whisper lid install
Originally posted by vr4gasm View Posti think whisper lids are overrated.. go with fipk :)
To the OP, nothing special needs to be done. Since you got a used lid the grommet for the IAT sensor should already be in place. Just make sure all the tabs on the back of the lid are lined up when you install it. Simple as that.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Originally posted by pace2006 View PostUseless post is useless. He already has a lid. :P
Originally posted by pilotb19 View PostIt didn't come with the grommet for the IAT but he said I could just use my stock one and just plug it in the the whisper lid. Will that work?
k&n fipk.....dont those cost $350+ dollars? LOL :twak: whisper lid is where its at.
Originally posted by whitdog54 View Postk&n fipk.....dont those cost $350+ dollars? LOL :twak: whisper lid is where its at.'99 Camaro
'04 Saab 9-3 Aero
You don't have a grommet in the neck of your stock lid? If not, you'll need to get one. Otherwise, the sensor wont fit right and will cause a leak. You can pick one up at a local parts store or from the dealership for about $2. Part number is GM # 24504388.
'99 Camaro
'04 Saab 9-3 Aero
Originally posted by pilotb19 View PostIf you look at the picture thats how it was when I pulled it out,so I can just buy that replacement one and stick it on the end of the sensor and it should fit in the whisper lid?
Thanks<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Thanks'99 Camaro
'04 Saab 9-3 Aero
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
