So I have been wondering...could i just completely eliminate the over the axle pipe and run a muffler underneath the car and dump before the axle? would it effect performance? i have no cat now btw. And would it sound better with a single in single out or a single in dual out with maybe a short pipe with a turndown on one side and a longer pipe going out with a turndown....like on each side of the car...if you get my drift....
another dumb exhaust question!
Re: another dumb exhaust question!
i dont have the money for s-pipe back :rant: and just curious how it would sound or effect performanceauto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
New Times coming soon
yes you can eliminate the tail pipes, over axle pipe, etc and dump the exhaust before the rear axle with a small turn down tip or whatever you want.
With the exhaust dumping out under your car it will resonantmore and will sound deeperish, might drone if you have a stupidly loud muffler.
Regarding the dual out with pipes on the side of your car that is possible as well but its pretty much the same as running dual tailpipes out the back except you wont have an over the axle pipe and all that.
Dumping it under the car is easy and cheap, make sure whatever tip you use isnt too long. My camaro is stock height and i scrap the tip every now and then.
hope that helps amigo
Thanks guys!I'm considering trying this. Now... How about mufflers? I'm thinking borla or dynomax probably.auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
you probably wouldnt want to use a muffler that is greater than 4'' thick, 3.5'' if your car is lowered
Dynomax FTW. Or for a mellow sound and cheap in price with still no rasp Summit Turbo muffler for $25.Last edited by ssms5411; 10-01-2009, 02:51 AM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Meatyshells View Postyou probably wouldnt want to use a muffler that is greater than 4'' thick, 3.5'' if your car is loweredauto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
will a single in single out muffler sound any different compared to a single in dual out muffler?auto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
lol well ill stay updated on that one as well. You have an xr-1 now right? is it single in single out or what? hows it soundauto, aluminum driveshaft, Fast Toys Ram Air, !air silencer, smoothed lid, Pacesetter shorties, 2 1/2" exhaust, !cat
New Time:
15.11@91.14
Team 3M Mafia
no i don't have an xr-1
this is a clip of borla xr-1
http://www.youtube.com/watch?v=4YfZ2...om=PL&index=11
best 3.8l i have ever heard for being n/a
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
