Do you have a chart I can look at? Is your car stick or auto?
Anyone dyno their 3800 when it was stock?
I dynoed mine stock, with the exception of gears... I will look around and see if i still have the chart.
I want to say it dynoed something to the tune of 176hp and 212tq... Its a manual btw.2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
Yeah i dynoed my 97 stock. (well it did have a K&N Filter) but i dynoed at 170hp and 210TQ. and my car is a 5 speed1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
Quick question...How did you guys get a full 3rd gear (1:1 ratio) dyno pull? Did you remove or disable the speed limiter? Or did you just shut it down when the limiter kicked in? [img]graemlins/burnout.gif[/img]<a href=\"http://www.geocities.com/MotorCity/Street/6330/VicCamaro.html\" target=\"_blank\"><b>*1997 Silver Camaro A4/3.08*</b></a><br /><b>Best 1/4</b>(December 17, 2003)<br />Race weight: 3580lbs w/driver <br />RT: .396 1/4: 14.93 60\': 2.08 MPH: 89.73<br /><b>Mods</b><br />>Flowmaster 80 muffler (muffler only) >Homemade cold air with K&N 1000cfm cone filter >Trans-go Shift Kit >2400-2600 TCI converter<p><b>*1969 Camaro SS*</b><br />*502ci (92-octane pump gas)<br />*2-speed powerglide<br /><b>Best 1/4:</b>1.34 60ft 9.78@138.12mph (Aug 16, 2003)
Yeah I was referring to 3rd for auto cars like mine. But you are correct 1:1 would be 4th gear on a manual. The hole reason why I haven't put my car on the dyno yet is I have heard many people say they have not got a full run do to the limiter. I mean in my car at 118mph I'm at like only 4300-4700rpm with the 3.08s in the rear...so...if all I can pull to is 4500rpm it would really be a waste of time and money in my opinion. What have all you done to get a good dyno on your cars? Thanks for the help.
[ December 25, 2003: Message edited by: Silver97Camaro ]</p><a href=\"http://www.geocities.com/MotorCity/Street/6330/VicCamaro.html\" target=\"_blank\"><b>*1997 Silver Camaro A4/3.08*</b></a><br /><b>Best 1/4</b>(December 17, 2003)<br />Race weight: 3580lbs w/driver <br />RT: .396 1/4: 14.93 60\': 2.08 MPH: 89.73<br /><b>Mods</b><br />>Flowmaster 80 muffler (muffler only) >Homemade cold air with K&N 1000cfm cone filter >Trans-go Shift Kit >2400-2600 TCI converter<p><b>*1969 Camaro SS*</b><br />*502ci (92-octane pump gas)<br />*2-speed powerglide<br /><b>Best 1/4:</b>1.34 60ft 9.78@138.12mph (Aug 16, 2003)
<blockquote>quote:</font><hr>Originally posted by MustangEater8251:
up;lug the VSS... should give be fine...<hr></blockquote>
00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
<blockquote>quote:</font><hr>Originally posted by snatch:
<hr></blockquote>
typo...
unplug the VSS (Vehicle Speed Sensor) Sticks out the side of the tranny, I have heard on 5-speed cars it will cause it to stall out at speeds coming to a top, then idling...
Doesn't read the vehicle speed thus will not hit a speed limiter also won't tell you your speed but you are on a Dyno, so it doesn't matter...
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
