Any idea why my drivers side front struts keep breaking. This is the 3rd time! It appers what happens is the sturt compresses, gets stuck down, the rippes it self out of the upper sturt mount. Im kinda pissed right now, so im going to cut this short, im just tired of all the repairs ive been having to do, this car is driven so easly its not even funny.
Struts breaking.
Struts breaking.
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
Re: Struts breaking.
HAve you figured out what's binding? i.e. spring, shock, suspension arms?Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Is this the 3rd time with the same strut or did you replace the strut with new each time this happened??Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Only thing I could guess is something on your suspension is loose or bent. Thus when the strut compresses, the loose or bent piece twists a little bit binding the strut under compression, and then it hold the strut as the suspension rebounds.
This is just a shot-in-the-dark problem I came up with. And it's the best way I could explain it. Hopefully you understand what I'm talking about.
OR- It could be a problem with the upper strut mounts. Maybe the bolts are stripped, which doesn't allow a firm hold at the top.sigpic
yes, i had to replace the sturt and upper sturt mount 3 times alrealy. I rips a hole right through the strut mount. First time i replaced it myself, then pepboys did it twice, now its done it again. Im been very busy at work and not in the mood to mess with this car when i only drive it on the weekends and have to fix a new problem every week after work. Ive been spending an average of 350 a month on repairs thats ive done myself and my mechanic on stuff i dont have time for. But i solved my problems, i traded it in yesterday for a GMC crewcab Z71 2006 white.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Is this the last we see of BobbyZ??Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
haha, yea, i wanted z71 for another site, but it was taken, and ever since on every site im a member of, my name is bobbyz72. plus its easy to remember and for others to find me.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...6 days ago
