Recently my car is making this funny noise. Whenever I'm slowing down and stepping on my brakes my car sounds like it's dragging something. This only happens when I'm going slowly, it also happens when I backup slowly as well. I don't know what's wrong with it. Someone once mentioned about their rear axle being dry and stuff like that but I'm not sure if that is the case. This only happen sometimes but now it's starting to be more frequent. Besides it sounding like dragging something it can also be described as like two metals scraping against each other (I guess). Does anyone have any idea what can be wrong? My car is a v6 2002 M5.
Dragging noise?
Re: Dragging noise?
Have you checked your rear diff fluid level and how many miles on the car?
Re: Dragging noise?
I'm not saying this is your problem but have you ever seen the Castrol GTX anti-sludge commercials where the guy is literally pulling a cruise ship's anchor??? LOL
Maybe you should try and find out where the sounds comming from? Get a friend to help if you have to2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Dragging noise?
Originally posted by Niko97RSmaybe your rotors are worn and you are grinding the pads into the rotor...you dont hear it at higher speed but when u hit the brakes going slow it sounds like a train is stopping...id check those first
Re: Dragging noise?
I broke my tourque arm bolts and it was leaning against the drive shaft making a nasty grinding noise! check that out for sure ;)MSN: inynn666@hotmail.com<br />1996 Arctic white -3800-<br />Pacesetter Headers & Y-Pipe, CAI, LS1 Dual Exhaust, LS1 Driveshaft<br />*15.17 @ 95MPH*
Re: Dragging noise?
this happened to me, and is probably the OP's problem
