I got everything plugged in, all interior stuff works except for my map lights, even gauges, but when I turn the key nothing happens, anyone got any ideas?
LS1 swap help! (paging all ls1 swap guys!)
how many harnesses did you swap, whats original?Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
damnit man you are beyond vauge.
What year is your car.
What year did you transplant into it?
Starters relay is activated by a fat purple wire that goes from the ignition all the way to the starter.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
use a volt meter
Where the engine harness meets the underhood harness you will have a purple wire that has 1 plug.. male into female... check the voltage of that when cranking position with key.
Check it at the starter.
Sure starter + goes to battery?
Perhaps its a bad starter.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
the teeth will stay back until it gets voltage. Then the gear will spin causing it to be pushed to the flywheel, and then the gear will move back after the key is let off. Thats so that the starter doesnt put any extra drag on the motor.1988 Pontiac Fiero Formula SOLD!<br />1999 Pontiac Firebird<br /><a href=\"http://members.sounddomain.com/tlight99\" target=\"_blank\">http://members.sounddomain.com/tlight99</a>
the starter body is ground.
The power all the time is the lead that goes to the battery..
The one that is switched is the relay signal.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
omg. you jupered things with paper clips?
You are just asking for trouble. if you jumper the starter leed or the starter relay wire and it arcs to the body your next post might be "Who wants to buy a charred f-body"
If I where you I'd stop right now and have a professional help you.
You may just cause more damage than good.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Really I have no idea what the problem is.
No offense but you are all over the place and are not describing what you are doing in detail at all.
"it is getting power" what is it, how did you check.. etc. etc.
You are using paperclips as juncitons. What happens when they arc and short?
I'm sorry but I just can't help you. You need to be more detailed and descriptive.
Also, I'm moving this to general tech.
I really wish I could help you and we could help you in advanced tech but this just is not the place for posts with 2 scentances and replies with 2 scentances.
We need details in here that are descriptive and show step by step what is done to help solve the problem and what steps have already been taken.
Good luck. Have some water near by just in case.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...1 day ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
