i've read about you guys hitting a dead spot between 40 and 50mph and i've noticed it with my 96 camaro too. is this common for all v6 fbodies and is there any way to fix it?
dead spot?
moving to General....Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015
called PCM reprogram, gm has a update for this, go have gm fix give you computer all the updateswww.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by viper04af:
called PCM reprogram, gm has a update for this, go have gm fix give you computer all the updates<a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
the dead spot is basically caused by the 3.08 gear ratio on most automatics, and since most city speed limits are 40-50, this affects street racing adversely. what happens, is you're cruising along at 40 in overdrive, very low RPM, so you floor it and it can't downshift to first because it isn't programmed to stay in first more than 40 mph.
the low rpm hurts you more from a roll because if you start in 1st then it winds it all the way up before shifting, so it just lags due to the gear ratio because it is really hard to spin the wheels with low RPM on such a tall ratio.
you can get 3.42s and that'll get rid of the dead spots by allowing the wheels to be spun easier, your rpms will increase faster, and it's a pretty solid all around performance increase.
This may be a dumb question if you were to upgrade to zexel lsd w 3.42 would you lose over drive? and couldn't you just leave it in overdrive off with 3.08 and shift it into overdrive on the highway once u hit 70 or 80?
[ February 18, 2004, 08:28 PM: Message edited by: wilkcamaro98 ]1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.
Get a shift kit. My car pretty much jumps from 40 to 48 when it shifts.1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
