Installed a 160 thermostat and the temp did not drop hardly any....
A thermostat DOES NOT control the engine temperature. It establishes the MINIMUM operating temperature only - the fans control the operating temperature above the minimum. Get a fan switch to lower the temperature.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
<blockquote>quote:</font><hr>Originally posted by FirebirdGT:
A thermostat DOES NOT control the engine temperature. It establishes the MINIMUM operating temperature only - the fans control the operating temperature above the minimum. Get a fan switch to lower the temperature.<hr></blockquote>
What he said..and yeah if you run the fans on low temp will be around 180 and if you use high they will be around 170
fan switchs are great
Jeff W
Do the fan switch mod. If not make sure you flushed your coolant and add new Dexcool. Add some Waterwetter too. It makes a big difference.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
The stock radiator is only good for a 125degree temp difference between ambient air - Damn Michigan Pontiac Engineers can't design a radiator for FL...
Anyways, this means that when its 40degF outside, youll have 165degF water temps.
If it goes above 40degF, your water temp will linearly go up as well...
I'm going to the SLP highcapacity radiator very soon, for $299 with 50% more core area (its thicker), its a great deal.2002 5-spd NBM Camaro
Details: www.1lev6.com
