on a dry clean street, wheels straight, my car wont even come close to spinning tires.
Traction Control???
Originally posted by 97burnout:
they made a change sometime cause my friend had traction control on his 2000 and my 97 only has a light that tell you when you lose traction...
bobby, do you have an open differential? Im guessing no, because you said "tireS".2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
not sure... from what I understand is traction control on v6s is wierd its a 3 channel TCS instead of a 4 channel like v8s...
The "low trac" light is with the abs... just telling you the wheel sensors are registering different speeds. Like if the rear or any other wheels were spinning.
IMO if you just bought the car, I'd do this regardless...
-seafoam
-fuel filter
-plugs
-wires w/ heat sheething
-flush the motor on oil change-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
too bad it doesnt tell you which wheels are spinning2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...4 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
