I have a 01 firebird that I just swapped motors on now I have this purge valve that I cannot find where it goes or even how it goes I have looked for diagrams of my motor but no luck I also cannot find where the sensor plug is either just very frustrated
I believe that goes on the left (as you're looking at the engine) side of the upper intake and hooks up to the sensor of the back of the upper intake, and comes forward behind the alternator.
1997 Chevrolet Camaro
I think there's a plastic line that hooks up to it as well on the other end. If you can't figure it out by the time I get off work ill look at my car for ya.
Thats your Evap sensor , if you have Hptuners you can delete it out if you wanted.
Is there anyway to bypass the purge valve and evaporative emission? I'm tired of getting the evaporative emission code and nothing I do fixes it. Thanks.
49 minutes ago
