So I thought I was finally out of the engine code woods and could get an inspection but I am now getting the 0441 evap code. I thought it was getting set as a fuel line (i think its the evap line) had a rotted rubber connector. I replaced with a small length of vinal tubing. Evap code is coming back. I frequently get a gas smell with a full tank and cornering. I think something in my evap system is leaky but haven't the foggiest where to start looking other than the canister which from what I am reading is in the rear wheel well. Has anyone had a stubborn evap code that could give me some pointers where to find my troubles? My inspection was up in May and i need to get a clear read on codes to pass NY emissions.
P0441 Evap code
Re: P0441 Evap code
Its the vac line from the TB to the solenoid. The replacement i put on there was angled too sharply and the rubber connectors deteriorated.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
