I have a 3.4l A4 transmission and I want to put some mods onn it (ie, transgo, corvette servo, b&m shifter+) and I wanted to make sure its all compatable. Thanks
what kind of tranny do i have...
4l60e borg warner automatic 4 speed transmissionFor Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering Springs
<blockquote>quote:</font><hr>Originally posted by PiLOTLiTE:
If he has a '93, I believe it will be a 4L60 and not a 4L60E.<hr></blockquote>
You are correct. If it is a 93 it is a different transmission.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
If it's a '95, you have a 4L60E.
Borg-Warner? That'd be news to me. The Turbo Hydramatics are GM transmissions, unless they started outsourcing recently.
Borg Warner builds, or built, the 5 and 6 speeds, though.
Brett, find yourself a competent tranny shop, and talk to them. If you're going to look into adding a bunch of stuff to the tranny, you might as well look into having it rebuilt also.
I was looking at getting the transmission from my 95 rebuilt, and the guy would have charged me $950 for the rebuild, plus the extra cost for the shift kit, high-perf clutches, etc., and would have installed everything as part of the rebuild.
Coordinate everything with him (he can probably also get a better price on the parts, too), and have him order the whole set-up together, that way, everything's there when he starts.
Also, there are fix-kits for the 4L60Es which he can also install, they should be part of a rebuild, ask about them. Superior Transmissions - http://superior-transmission.com/ - has all the stuff needed for a rebuild, including shift kits, etc.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
