Putting in a new clutch I have the tranny ready to be unbolted from the engine and pulled back only problem i am having is disconnecting the hydraulic hose from the slave cylinder I have tried every fuel/ac/radiator release tool from the three closest auto parts stores and got nothing they wont fit inside any idea on how to get the hose unhooked? Gotta have this finished by tomorrow.
Help disconnecting hydraulic hose from slave cylinder
Re: Help disconnecting hydraulic hose from slave cylinder
I used a flathead screwdriver. Push the hose all the way in, push on one side of the connector, then the otherside, then it should pop out. Many people have trouble with this, but I got it on my second try.
I just use an end wrench that is just big enough to get over that fitting, then push that white plastic thing down. Never had any problems. When you push it down hold it there and pull the hose out of the fitting, it dosnt just pop out.1997 Chevrolet Camaro
Lol nothing worked it wouldnt budge so I just took a die grinder to the outer cover and then took a flat head and pried till the braided hose came free... lol wanted to get a new slave cylinder anyhow. Is there anything special i should do with the new one before putting it in or can I bleed everything once clutch and tranny are back together? Right now my progress is frozen though cant get the top two bolts out holding the bell housing only extensions i have to reach are 3/8s and i cant get enough torque to break them loose will buy half inch extensions and flex joint tomorrow morning.
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...3 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
