Help disconnecting hydraulic hose from slave cylinder - FirebirdV6.com/CamaroV6.com Message Board
  • Help disconnecting hydraulic hose from slave cylinder
    Putting in a new clutch I have the tranny ready to be unbolted from the engine and pulled back only problem i am having is disconnecting the hydraulic hose from the slave cylinder I have tried every fuel/ac/radiator release tool from the three closest auto parts stores and got nothing they wont fit inside any idea on how to get the hose unhooked? Gotta have this finished by tomorrow.
    Re: Help disconnecting hydraulic hose from slave cylinder
    I used a flathead screwdriver. Push the hose all the way in, push on one side of the connector, then the otherside, then it should pop out. Many people have trouble with this, but I got it on my second try.
      I just use an end wrench that is just big enough to get over that fitting, then push that white plastic thing down. Never had any problems. When you push it down hold it there and pull the hose out of the fitting, it dosnt just pop out.
      1997 Chevrolet Camaro
        Lol nothing worked it wouldnt budge so I just took a die grinder to the outer cover and then took a flat head and pried till the braided hose came free... lol wanted to get a new slave cylinder anyhow. Is there anything special i should do with the new one before putting it in or can I bleed everything once clutch and tranny are back together? Right now my progress is frozen though cant get the top two bolts out holding the bell housing only extensions i have to reach are 3/8s and i cant get enough torque to break them loose will buy half inch extensions and flex joint tomorrow morning.
          Just try again. I got mine out using a two foot extension, and a swivel joint. Didn't really take all that much force, although I did also use a breaker bar.
            Me and my buddy had the 3/8"s twisted a whole 180 degrees we were both pushing bolt still didnt budge lol, just a bunch of twisted extensions. 1/2" ftw tomorrow hopefully
            • LETZRIDE
              New Owner!
              by LETZRIDE
              3 days ago
              Little work today
            • LETZRIDE
              by LETZRIDE
              Building the Tom Henry RS
              By: Hib Halverson
              02-07-2020, 10:30 PM
