im thinking about having the engine i just bought rebuilt with the 4.2 stroker kit from 3800stroked.com. just wondering if anybody on this site has done it yet??? i searched and everything i found was just people dreaming about it. if so what do you think about it??? is it worth the 3200.00 or would a turbo be a better route?? thanks in advance for any info.
Anybody on here have a stroked 4.2??
Re: Anybody on here have a stroked 4.2??
Originally posted by jrherald420 View Postyeah it would but i wouldnt want to invest 3200.00 into a stroker kit thats not good. then again it seems like nobody likes a stroker engine....
Originally posted by a-master View Postwhat do you do to the engine to get it 4.2l, bore it our? swap?
and you can bore our engines, i think ive heard like .030 safely? right thor?
but others have gone higher, such as .060
but what the OP is looking at was a stroker kit which increases the displacement by making the piston travel further. so that would put you at 4.2l
only bad stroker kits that I have heard of were the zzp ones but they stopped making those.
The COME racing kit nobody has done in an fbody car yet. They run them over in australia without issues in the holden cars. Also a few grand prix guys are working on 4.2l stroker builds.
The COME kit is a nice kit though and would make some nice torque
www.3800stroked.com is the seller of the COME kits
My only question would be how would this effect vibration, assuming that the balance shaft would probably be deleted to opt for a double roller? As I understand, balance is key so that the motor doesn't rattle fillings out as a 3.8L. Stands to reason that baby would most definitely rock in the cradle as a 4.2L.
many guys are running dbl roller timing chains with no issues...I doubt it would be a problem....
Originally posted by steddy View PostMy only question would be how would this effect vibration, assuming that the balance shaft would probably be deleted to opt for a double roller? As I understand, balance is key so that the motor doesn't rattle fillings out as a 3.8L. Stands to reason that baby would most definitely rock in the cradle as a 4.2L.
Originally posted by 97rs4life View Postonly bad stroker kits that I have heard of were the zzp ones but they stopped making those.
thats the one im looking at....but before i would slap down the cash i would want to know what else would have to be done(like valve train and such...) and yes i did search about this and couldnt find any info from people that have done this.
I have decided to keep my single chain and just run 105lb springs, should be good enough for 400hp, with keeping the shifting under 6000 RPMS. There are a few that have kept their singles running turbos , so I will try it also.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by jrherald420 View Postthats the one im looking at....but before i would slap down the cash i would want to know what else would have to be done(like valve train and such...) and yes i did search about this and couldnt find any info from people that have done this.
