Cam, am I ready? - FirebirdV6.com/CamaroV6.com Message Board
Cam, am I ready?
  • #31
    Re: Cam, am I ready?
    Originally posted by Fireball27
    Thats not really true anymore...
    yes, and said hardware is on the OP's to-buy list?
    • #32
      I have a custom grind, very similar to the GT2, it ran with no tune just fine.
      I ran nitrous with it as well.
      Don't buy a nitrous cam unless the car only makes passes on spray, and has larger than a 150 shot or so.
      The gt2 and some headers and a high flow cat will be enough for the nitrous.
      You can run it on stock valvetrain if you so desire, I would at least put in a fresh set of springs, if not aftermarket, than stock.
      1997 Dodge Viper GTS
      • #33
        Cam, 105# Springs, Spring Retainers. Should be all I need, right?
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
        • #34
          all gaskets, rocker arm bolts, new head bolts/studs, injector O rings ( i would), pulley puller,
          might be missing some things
          • #35
            Have a pulley puller, so I should just need this> Cam Install Kit
            ~97 3.8L V6 Camaro~
            A few things
            • #36
              hmmm, link didnt work, but be careful with the ZZP cam install kit, you need a new cam bolt and crank bolt....the crank bolt they provide is for the L67 and will not work.
              also i would recommend going double roller timing chain as long as you are in there.
              • #37
                Timing Chain
                Cam Install Kit
                Kit #4, made for the L36:
                Kit 4 includes:
                *12 rocker bolts
                *intake gasket set
                *front cover gasket
                *ARP assembly lube
                *valve cover gaskets
                *crank bolt
                *cam bolt
                ~97 3.8L V6 Camaro~
                A few things
                • #38
                  Why? I run a nitrous cam and the car has never been run on nitrous or boost yet. Best time is a 14.3 on stock manifolds, street tires, stock stall, and a fair tune.
                  Camaro V6 - 14.3 @ 96mph
                  Camaro SS - cam/boltons/m6/tune
                  http://www.crfhq.com
                  • #39
                    Originally posted by RadRacer
                    Timing Chain
                    Cam Install Kit
                    Kit 4 includes:
                    *12 rocker bolts
                    *intake gasket set
                    *front cover gasket
                    *ARP assembly lube
                    *crank bolt
                    *cam bolt
                    You'll also need to buy an upper intake manifold gasket set(most auto parts
                    stores have it listed under plenum gasket) and a throttle body gasket. Most
                    of the time the throttle body gasket comes with the upper intake mani gasket.
                    • LETZRIDE
                      New Owner!
                      by LETZRIDE
                      4 days ago
                      Little work today
                    • LETZRIDE
                      by LETZRIDE
                      Building the Tom Henry RS
                      By: Hib Halverson
                      02-07-2020, 10:30 PM
