So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover gasket and new crank bolt, just need more oil and coolant and should be set.
Leaking front cover
I think I’m going to try the GM coolant tabs first to see if it stops the leaking, it’s a small leak. I hate to use a additive but low on funds.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostIt's not coming from the weep hole of the water pump?
Got the tablets in Thursday, did 3 of them. Was having trouble with getting my temp up at idle, only would go to 179 degrees then fans would kick on. So hooked up Hptuners and turned the fans off . Got to around 195 degrees so my 180 thermostat opened. Will do this a few days then check for leaks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the temp up to 210 a couple of times, cleaned my drip pan. Going to keep an eye on it this week. Hopefully it’s stopped leaking. Starting to warm up so might take it out for a spin.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So far so good, no coolant on the pan, had a small oil leak too, so tried some STP high mileage with stop leak. So far it’s not leaking.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Still no coolant leaking, smaller oil leak give it another week then I’ll add more. If I can get the cars off the driveway I’ll take it out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Checked it today and very minimal amount of oil on the drip pan.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Still leaking a little oil, going to drive it more, says it needs driven 200 miles .08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
