My son says his 2002 V6 Camaro has a sound that I finally heard tonight. Sounds like a lifter to me. Taps really loud when engine is cold and revs with the engine's RPM. He goes to college 200 miles away so I don't get to check it out very often. He says the sound comes and goes. Collapsed lifter maybe? Is it something to be really concerned with? Any solutions short of replacing lifters? I wonder what that will cost?
Help identifying a sound
Re: Help identifying a sound
try to get him to take a video of the sound and post it. That's the easiest.In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
Never thought of that and since he is an Electronic Arts (Computer Animation) major he should be able to do that. I'll attach that next time,
A shop I sometimes use suggested a BG engine flush and oil change. They said it would be under $100. Anyone have experience with that?
Sound like this?
http://www.youtube.com/watch?v=9CClUSBlsGc
http://www.youtube.com/watch?v=yzlLaQXIxeY
http://www.youtube.com/watch?v=mOCyT-l47es
None of those were very distinctive but I found a few others that were. All were lifters clacking. I'm going to try the Seafoam treatment Wednesday when it's supposed to be warmer. I'll let y'all know how that goes.
Originally posted by Winch View PostNever thought of that and since he is an Electronic Arts (Computer Animation) major he should be able to do that. I'll attach that next time,
A shop I sometimes use suggested a BG engine flush and oil change. They said it would be under $100. Anyone have experience with that?In America's Hat!
I don't have a video of the sound yet. I put Seafoam in the oil as instructed and it has helped a little. We haven't driven it much yet to see if it's going to clear it up. I'm sure the sound is a lifter and now it's only when he first starts the car and it goes away in a couple of minutes.
When I put the Seafoam in I noticed light beige foam in the oil input tube and the cap (see pic). It doesn't appear to be on down in the tube and the oil on the dipstick looks good. I've never seen this. It looks like when oil and water get mixed. Can there be condensation at the top of the tube?
Originally posted by Docta View Postlooks like condensation. not oil-coolant mix...08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
He said a shop he uses suggested a engine flush, other than that they would have to start pulling parts off to see whats wrong. I only have one mechanic that I trust my car to and I haven't seen him for about 8 years. I like doing the work myself, like others who post on here. Save money and enjoy working on cars.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You want to be careful with an engine flush.
I think I'd pull one rocker cover, first. If you see a lot more of that tan "shaving creme" stuff, put the cover back on and tear the engine down because it likely has a coolant leak into the engine, perhaps from a head gasket.
If you get the cover off an find a lot of oil sludge, an engine flush can be a "double-edged" sword. Sometimes it loosens/dissolves so much sludge that the oil filter and small oil passages become restricted. If the engine is badly sludged, it means the oil was not changed often enough. If the engine is also high-mileage, it likely needs an overhaul.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...23 hours ago
