The SLP fan switch is awesome, plug and play can't go wrong with it, I ve had it for 15 years or so.
Hello to all!
Finally! here are some pictures of the area between the air filter box and the fuse/ relay box. The additional relay was wired into what I think is the #3 cooling fan relay, under the fuse box. The wire with the blue crimp is the ground that completes the circuit. I seem to be missing a relay for the "air pump" however. That has to do with the emissions system, right? As for the manual fan switch, i'll be stubborn and make one on my own with a dpdt switch.Last edited by Migo54; 01-24-2019, 10:19 PM.
Originally posted by Migo54 View PostFinally! here are some pictures of the area between the air filter box and the fuse/ relay box. The additional relay was wired into what I think is the #3 cooling fan relay, under the fuse box. The wire with the blue crimp is the ground that completes the circuit. I seem to be missing a relay for the "air pump" however. That has to do with the emissions system, right? As for the manual fan switch, i'll be stubborn and make one on my own with a dpdt switch.
I would still do a SLP fan switch so much cleaner looking and plug and play . Can't go wrong with it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Here is a little update: I deleted the extra relay powering the fans, and thankfully the connections weren't permanent. I ran my own wiring into the car and hooked up a switch for the fan, saving myself about 40 dollars (yes, money is tight and precious still). Next thing to go are the Chinese tires and perhaps the squeaky bushings. Thanks for the suggestions and help, but I dont mind a little of DIY once in a while.
Edit: here is some more; the car left me stranded twice now with the engine starting, idling very roughly and stalling out. After about half an hour of fiddling under the hood (doing visual checks), the car would start just fine. After the second time, I replaced the fuel filter and It seemed to help out, however the old filter had the paper element loose inside the metal case.Last edited by Migo54; 02-15-2019, 02:46 PM.
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...3 weeks ago
been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place...4 weeks ago
