I'm back - 2002 Pontiac Firbird v6 - FirebirdV6.com/CamaroV6.com Message Board
  • I'm back - 2002 Pontiac Firbird v6
    back in 2013 I had a convertible 2000 firebird, sold it because I didn't want to do anything more as I had a new love for the nissans,
    Recently, I acquired a new firebird. black on black 2002 Pontiac Firebird v6 for $300, blown headgasket but clean with T tops,
    so far replaced the headgaskets and regasket the whole upper intake but now trying to get it started has became a challenge.
    Currently as the motor is having a hard time to turn over. It is getting fuel and spark is there followed the book to the T on the removal and reinstall of the heads and so on.
    70k miles can't go wrong with this one or can it?
    I would double check all the connections on the wiring, does it try to turn over?
      If it helps any it kinda does here is a 30s video showing when attempting to turn it over.
      https://youtu.be/peL3XLdRgBE
      Currently I have triple checked alot of the wiring and connections something still seems off, next I am going to change out the fuel filter just to be on the safe side.
      It gets fuel, I don't know the pressure till tomorrow after I acquire the tool to test. Compression it is getting around 130-140ishpsi on all 6 cyl,
        Yeah , thats werid, any trouble codes?
          With the ecu reset, I can't get any codes to throw up with my code reader shows blank in the codes. Being that I am in vegas have been dealing with some stuff, Hopefully I can rent the tool in the next day or 2 to check the fuel pressure, replaced the fuel filter and it is starting to act a bit better when attempting to start her but still no fire.
            Sounds like you have a slow crank or is that you just pulling off the key really early? If it is a slow crank make sure all of your connections to your battery are tight and clean...then make sure the connections to the alternator and starter are also tight and clean (free of any corrosion). Once that is checked out, verify all of your grounds are clean and tight - specifically as you mentioned you did a headgasket repair check the ground that goes to the back of the head drive side...that can get pinched and or break fairly easily if you aren't careful and if memory serves me right is the ground for your coil packs. I've pinched this between the head before but luckily noticed before I bolted it all down.
            If you had the crank pulley off there is also the crank sensor wire that can be easily pinched by the crank pulley/and or front cover and cause a no start condition due to lack of signal.
            Check the fuel pressure and also let us know if you are getting spark on all 6 cylinders
              Thanks, that is actually some good information there I will double check more grounds but the cranking is getting better as I am finding more things. I did find the one behind the head and was able to get that one when I was pulling the starter and checking it.
              If the coil packs has a ground also as I am pretty sure I didn't hook up an extra ground between them 2.
                I am 99% sure there is one behind the head on the side of the coil packs (driver side)...I damaged mine and had ended up relocating it to the front of the head for ease of access
                • Andy H
                  Hello everyone!
                  by Andy H
                • 3.4 slow to go
                  hey there strangers!
                  by 3.4 slow to go
