I just got my new Camaro ( :D ), which has the Y87 package ( :D :D ). I also have a set of SLP Bilstein shocks sitting at home.
Does anybody know if the Y87 different shocks from stock, and are the Bilsteins stiffer (stronger, etc.) than what I have now?
Thanks.
Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
the regular bilsteins (hd) which you can buy at autozone and many other places (vs the slp revalved bilsteins) are supposed to be an improvment over the stock shocks. so if you have the regular bilsteins and are sticking with stock ride height then go ahead and bolt up the bilsteins, then go find some fun twisties and enjoy..
-Brad
2000 V-Star Custom 1100
:rock:
I have the SLP Bilsteins, which I read somewhere are valved a little less aggresively than the standard Bilteins. Any idea how much of a difference. The rear end of the car does the dance going over bumps and such at 70+ :D mph, and I need to know if the SLPs will help, or if I would be better off trading those for a set of regular Bilsteins. Thanks.
Get a hold of Sam Strano and talk to him. I posted his number in this forum so do a search. SLP Bilsteins are too soft. Regular are still to soft. He valves them for the spring you'd be using.
6 days ago
