ok, I found out where the o2 ensor is, like plugged into the exhaust, but I can't seem to see where the wire (the other side of the sensor...) goes off to...it kind of just goes up into the tranny area. I only have the car jacked up too, which is a pain in the arse. I'd really appreciate it if someone would either point me in the right direction or walk me through it, even with pics maybe. I really need help. I bought a new bosch o2 sensor...also do I need special tools to get the sensor out? thanks
post cat o2 sensor replacement...HELP!!!
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>Tags: None
Re: post cat o2 sensor replacement...HELP!!!
follow the wire. there should be a connector jack. It has a clip into slot where the ends meet. to get the O2 loose, you probably gunna need a breaker bar and lots of leverageHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
shoot, I think I might have been trying to get to the wrong o2 sensor....it is supposed to be the "right bank" o2 sensor on the passenger side. Where is it located? I can't seem to find it. im a mechanic for the army, and I mostly work on diesel engines which are different. not used to this 3.8 efi. anyways a little help would be nice. and thanks for the respose!#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
check behind the cat. there is also one right past the exhaust manifoldsHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
damnit I wish i had written down the code for the ses light while I was at autozone. iirc, she told me that its bank 2 sensor 2 maybe? where would that be? can't find anything on google.... :(#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
I could swear that she told me it was "o2 sensor heater circuit malfunction (post- converter sensor, right bank)" if this is the case, where could I find the correct sensor? Thanks in advance!#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
hah! went back to autozone and had the ses light ran again...heres the results. po155
o2 sensor heater circuit malfunction preconverter sensor right bank...
mmkay with that in mind...where the hell is that sensor located? :-\#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Autozone or any auto parts store should have loaner tools and they should have a set of sockets for taking out oxygen sensors. The set I used used 3/8 connectors and I just used a regular wrench. You should run your car for a few minutes to heat up the manifolds, it helps with removing the sensors.
i got it thanks everybody!#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
