post cat o2 sensor replacement...HELP!!! - FirebirdV6.com/CamaroV6.com Message Board
  • post cat o2 sensor replacement...HELP!!!
    ok, I found out where the o2 ensor is, like plugged into the exhaust, but I can't seem to see where the wire (the other side of the sensor...) goes off to...it kind of just goes up into the tranny area. I only have the car jacked up too, which is a pain in the arse. I'd really appreciate it if someone would either point me in the right direction or walk me through it, even with pics maybe. I really need help. I bought a new bosch o2 sensor...also do I need special tools to get the sensor out? thanks
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: post cat o2 sensor replacement...HELP!!!
    follow the wire. there should be a connector jack. It has a clip into slot where the ends meet. to get the O2 loose, you probably gunna need a breaker bar and lots of leverage
      shoot, I think I might have been trying to get to the wrong o2 sensor....it is supposed to be the "right bank" o2 sensor on the passenger side. Where is it located? I can't seem to find it. im a mechanic for the army, and I mostly work on diesel engines which are different. not used to this 3.8 efi. anyways a little help would be nice. and thanks for the respose!
        check behind the cat. there is also one right past the exhaust manifolds
          damnit I wish i had written down the code for the ses light while I was at autozone. iirc, she told me that its bank 2 sensor 2 maybe? where would that be? can't find anything on google.... :(
            I could swear that she told me it was "o2 sensor heater circuit malfunction (post- converter sensor, right bank)" if this is the case, where could I find the correct sensor? Thanks in advance!
              hah! went back to autozone and had the ses light ran again...heres the results. po155
              o2 sensor heater circuit malfunction preconverter sensor right bank...
              mmkay with that in mind...where the hell is that sensor located? :-\
                it's on the bottom of the manifold before the y-pipe on the 00-02 manis. I think it may be in the back on top of the pre 00 manis.
                1996 Chevrolet Camaro
                1995 Buick Park Avenue Ultra
                --Appearance Moderator--
                  Autozone or any auto parts store should have loaner tools and they should have a set of sockets for taking out oxygen sensors. The set I used used 3/8 connectors and I just used a regular wrench. You should run your car for a few minutes to heat up the manifolds, it helps with removing the sensors.
                    Careful not to strip the bungs.. that's a whole other heap of trouble I'm sure you can imagine. As far as I remember it's a lot easier to get to them from under the car.
                    TEAM C6V6
                      Getting them out can be a b* if you don't have a lift. I got one out with an impact wrench and an o2 socket. Heating and using wd40 helps, but not much. And don't strip the sensor, that's a weld repair.
                        You really had to use an impact to get one out? Jeese little boy grow some muscles!
                        TEAM C6V6
                          Use some anti-seize on the next one ... I'm pretty sure the Bosch sensors already have some on it so next time it isn't so hard.
                            i got it thanks everybody!
