Alright, I just bought some 36# stock GTP injectors and wondered if I could just take the injector table #'s from a GTP and call it good for tuning the new injectors in?
GTP injectors
Tags: None
Re: GTP injectors
The stock 98 GTP flowrate Vs. KPA
from 0-100vac
steadily increases from 36.1 to 38.4 across the band.
I would copy the stock GTP one and log runs, then edit from there.
36.1 36.51 37.03 37.76 37.91 37.99 38.04 38.1 38.14 38.28 38.4
That is the stock values from 0-100vac for a 98 GTP.
Re: GTP injectors
I looked at a 97 gtp and they had it set to 36.28 across the board and then a 99 had it increasing from 36.10 like the 98. Andrew mentioned in his tuning guide to make the flow rates the same across the board to make it easier to tune
Re: GTP injectors
Originally posted by NachiusThe GTP being supercharged steadily increases fuel across the board to compensate for the boost.
Re: GTP injectors
Originally posted by 97rs4lifeduh! stupid me, I forgot about needing the fuel for the extra boost as it increases. Thanks Nachius.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: GTP injectors
do I have to do a case learn or anything after the injector swap or do I just have to reset the fuel trims so the PCM relearns them with the new injectors?
Re: GTP injectors
Originally posted by iGoRaYes - othewise it uses the old trims for some reason.
Re: GTP injectors
Originally posted by slow6I have a hypothesis that you only need the injector rate incrementing until you get to your PE. Then the injector rate can be the same which might actually be easier to tune PE. I really dont know but it makes sense to me... I just need to start massive R & D
Re: GTP injectors
yea, my stock injectors only liked the stock table(which is incremented) or "22.99" across the board2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...5 days ago
