i have some 3.23s sittin in my room and i'm contemplating puttin them in... what would be the best way to turn for these?? also would it hurt my gas mileage any? lastly... i've never seen the diference in a open diferential and a LSD... how do i tell if its got LSD or not?
tunings for 3.23s
PCM retuned for gears through texas-speed.com
Jack up rear of car, spin tire and see what the opposite rear tire does. If it goes opposite you have open, go the same direction, LSD.
If you have 3.08's stock you're probably going to need a 3-series differential to mount up those 3.23's unless they're made for a 2-series carrier.
3.08 -> 3.23 is such a small step. You will notice it a little but if going through the expense to have them installed I would recommend going bigger.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
do you drive highway or city most?
is it auto or manual?
do you want to accelerate faster
or do you want to accelerate slower, but get into higher MPHs?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
at the LEAST i would recommend nothing smaller than 3.42s2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
i dont really want alot more.. just a little more... and i dont wanna lose any more mpg cause i'm only gettin like 19 or 20...and its a daily driver so i cant send off the PCM...
97rs i know how to check if the gears in there have LSD.. i meant how do i check the gears that are sittin in my room for lsd1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
[ February 11, 2006, 12:53 AM: Message edited by: 98Camaro3.8 ]Matt
1998 Mystic Teal Camaro M5
ok well i dont know what a diferential looks like or anything i've never took apart rear ends or anything... i want to know if i have lsd or open with the gears that are sitting in my room1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
the carrier make it open or LSD not the gearswww.turbov6camaro.com
1997 3800 Series II Camaro
i guess i'm not puttin it into words good enough... everything needed for a gear swap is back there... gears carrier everthing... what the hell diference is there between the open and lsd is there so i can tell them apart1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Nobody has a clue what you're asking.
Do you want to know how to tell the difference between an open differential and a limited slip differential by sight?
Do you want to know which one you currently have in your car?
Do you want to know how the 2 operate differently?
Need to make some sense so we can figure out what your question is.Matt
Do you need to know the "visual differnences" between an open diff, and a LSD?
(seen some posts and I have a zexel, and a open sitting in my garage and have a few pictures of the auburn in my car, so I can take some pics and upload if REALLY needed, but I really don't want to if I have to)
As for going form 3.08-3.23, if your paying for a gear install, upgrade to 3.42s.
If you just have the spare rear laying around with a lsd and you are throwing it in. I'd slap it in, its an improvement and not insanely hard.
I noticed nice gains going form 3.23-3.42, and I have seen people enjoy the gain 3.42-3.73 its not the biggest gain you could get but its a gian.
IMO not worth the effort of paying someone to install if you are worried about your mpg.
and btw your mpg is crappy, I am getting 22 city, with 3.23 and 5-speed. Make sure everything is running right on your car.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
3.08s to 3.42s was a nice jump...
3.42s to 4.10s will be even better :D
The 3.23s will leave you wanting for more, and with install prices being rediculosly high I also would recommend at least 3.42s.97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
my MPG with 3.42 gears and A4 tranny is 19-20 city and 26+ on freeway.
I zip around town most of the time. not sure how to drive this car slow.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...5 days ago
