Removing torque management elements... - FirebirdV6.com/CamaroV6.com Message Board
  • Removing torque management elements...
    Remember I am a noob
    ok guys think I am running into TM KR at my shifts... I get from 1-5 degrees on some of my shifts...
    I have a 5-speed.
    so when I got to the typical transmission TM removal guide of, all my stuff is already done.
    1.DISABLE ALL TORQUE MANAGEMENT – This will eliminate all torque management within the PCM. Ignore this step for a standard transmission (M6) and continue to step 2.
    A. Open the VCM Editor>Edit>Transmission>Torque Management
    B. Set Abuse Mode Enable = False
    C. Set Abuse Mode RPM, Abuse Mode TPS and Abuse Mode Speed = 0
    D. Select>Abuse Mode Torque Reduction vs. RPM. Set all values = 0
    Now moving on...
    under the EDIT>ENGINE>TORQUE MANAGEMENT menu
    there is a table for RETARD vs. % TORQUE REDUCTION
    under that it has values... should I set all these values to 0? Or should I just reduce them or just leave them be.
    Thanks in advance... to me the values in the other tables look like they have values I don't have to worry about.
    any other help in reducing TM is appreciated
    Also should I change anything under the "abuse" section as well?
