Going through my logs today I was reminded that I am maxing out my 36# injectors...I seem to be sitting at roughly 90% injector duty at WOT when I had it on the dyno...how do I know which injectors I should upgrade to? 42.5 or 60#'s? The UIM/LIM are 100% stock still, so those will eventually be swapped/modded so I'm thinking the 42.5 *might* be ok for now? but what about with additional intake manifold work done?
fuel injectors
fuel injectors
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: fuel injectors
I P/P my own and they came out great even the TB. Aren't you running bigger valves on your heads? I'm running the Manely valves which are bigger than stock and with 65lb injectors I'm not even close to maxing and their priced about the same so might as well do 65lbers.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: fuel injectors
Originally posted by ssms5411 View PostI P/P my own and they came out great even the TB. Aren't you running bigger valves on your heads? I'm running the Manely valves which are bigger than stock and with 65lb injectors I'm not even close to maxing and their priced about the same so might as well do 65lbers.
the ARH cam only had me at like 65-70% duty...I'm pretty steady at 90% in the upper rpm's now with the new cam it looks like...same kinda tune as the ARH just more fuel added obviously to compensate for the AFR leaning out.
Re: fuel injectors
Originally posted by Meemperor View PostWhat is the total HP goal? With a 36# injector you should be able to get approx 265whp out it at 80% duty cycle, assuming 25% drive train loss.
I lied to you though when I was talking to you about this...I said she was at 12.4 afr across the board...when she hits 90% she's leaning out to 12.9afr...I didn't realize that until I looked at the scan again last night.
Seems to be at 5300rpm I am at 78-80%, by 5600rpm I am at 88%, and 90% by 6000rpm. At the start of the run at 4900rpm I am as low as 69% duty.
I guess from here I still want to stay N/A for now so its just a matter of how much hp I can gain from swapping to a custom Holden intake manifold...since no one really has hp numbers, I dont know how much I can increase my hp by, by doing a swap and p&ping it along with a custom top (whatever that ends up being)
Re: fuel injectors
I would go with the 65lbers(60 on ours) incase you do a dry shot of nitrous you'll have plenty to go 12's or even 11's with a 100 shot. The price for 42.5 lb injectors is pretty close to 65lbers so might as well get the bigger injectors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: fuel injectors
Also the 36lb injectors are more like 33lbs on our fuel system.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: fuel injectors
Originally posted by ssms5411 View PostI would go with the 65lbers(60 on ours) incase you do a dry shot of nitrous you'll have plenty to go 12's or even 11's with a 100 shot. The price for 42.5 lb injectors is pretty close to 65lbers so might as well get the bigger injectors.
You're running a Walbro and hotwire kit right?
Re: fuel injectors
Yup, walboro and hotwire...only thing I haven't installed yet from that kit was the 8 gauge ground that came as a bonus for the battery....I gotta find time to do that... Ya I'm kind of suprised I'm running out of injector to to be honest...
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
